bgyglfr's Avatar
Is this case worth saving?
I pick this engine case up with another engine I bought. Not sure if it’s salvageable or if it’s even worth saving. It had a rod come loose and beat up part of the internals. It’s a M96/70 case which I’m told it desirable. I usually stick to earlier stuf so it’s out of my wheelhouse. What do you guys think?
70T 2.7RS spec.
68L coupe
Old 09-16-2019, 11:38 AM
bgyglfr's Avatar
70T 2.7RS spec.
68L coupe
Old 09-16-2019, 11:40 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Total junk. Just send it to me and I'll take it off your hands.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-16-2019, 12:33 PM
Walt Fricke's Avatar
As beat up cases go, that one isn't all that beat up. Maybe have the internal webbing, where the rod bashed it, welded up.
Old 09-16-2019, 02:29 PM
Amateur
pmax's Avatar
Depends on whether it still holds water.
I don't need that.
Old 09-16-2019, 03:07 PM
bgyglfr's Avatar
Yeah. I think that’s where the last two pics come in. I think that hole is where the water moves through the case. That said, I was told that this case can be used to build an air cooled engine. All I can find for a M96/70 is gt2 and turbo case. Does that make any sense?
70T 2.7RS spec.
68L coupe
Old 09-16-2019, 03:37 PM
bgyglfr's Avatar
A couple pics of the complete case.
70T 2.7RS spec.
68L coupe
Old 09-16-2019, 03:42 PM
Engine Case Guy
I have a case that is worse than that where a rod tried to go through the same spot. Check for cracks on the other side. If It's not cracked, that case is VERY salvageable.
You won't get top dollar for it but it will run again.
Current: 1970 914-6 conversion 2.7, 1973 T, 1975 930 Turbo Targa, 1978 928 Race car, 6.57L, 1983 911SC, 1987 928S4 5 speed, 2002 911 Targa, 2007 997TT, 2009 997TT, 2004 40th Anniversary Carrera, Mclaren 570S and 12C
Only reproduction 3.6 cases on the planet www.taorminaracingdesigns.com
Old 09-16-2019, 03:55 PM
gearhead
Originally Posted by bgyglfr View Post
Yeah. I think thatís where the last two pics come in. I think that hole is where the water moves through the case. That said, I was told that this case can be used to build an air cooled engine. All I can find for a M96/70 is gt2 and turbo case. Does that make any sense?
Itís a 996 turbo case. Know nothing about building it aircooled.
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 09-16-2019, 04:15 PM
Weld it up, pressure test it, and run it! Put Carrillo's in it instead of the stock rods; those are the weak link in the 996tt engines.
Dunno about making one air cooled. Never knew anyone who tried. Water cooling got you heads that flowed a LOT better.
Old 09-17-2019, 04:42 AM
bgyglfr's Avatar
Well. All I have are the case, a set of P&Cs, and three heads. I’m not sure I have the cash to build it. I’m probably just going to sell it all tomsomone who has the rest and needs a case. Anyone have an idea what to ask? I’m happy to make someone a deal. Not trying to make a ton on it. I figure on the low end of whatever the market is.
70T 2.7RS spec.
68L coupe
Old 09-17-2019, 07:06 AM
bgyglfr's Avatar
So. It has 964 casting numbers. Did they use 964 casting numbers on 996 turbo or gt2 cases? Is it possible that this is a 964 turbo case?
70T 2.7RS spec.
68L coupe
Old 09-17-2019, 11:34 AM
Engine Case Guy
No, it's not a 964 turbo case because your oil return tubes are blocked.
What IS WEIRD is that it has the bosses for the air deflectors under the cylinders. This is extremely unusual on a water cooled case - they eliminated these.
So what you have is either a very early water cooled (prototype?) case using air cooled features before they changed the tooling.
Super cool find.
Old 09-17-2019, 11:57 AM
bgyglfr's Avatar
So. I wonder if it is actually possible to convert it to an air cooled case?
70T 2.7RS spec.
68L coupe
Old 09-17-2019, 04:12 PM
Engine Case Guy
Yes, you need to drill out the oil return tubes and thread some holes (like the air deflector boss mounting holes) and a few other things.
Should be possible to convert.
Old 09-17-2019, 05:59 PM
That Guy
Techno Duck's Avatar
Pretty sure that is just an early 996tt case. They all had the 964 part number until around '04 when it changed to a 996 number. Some '04 996 GT3's have the 964 case also. In your first picture showing the case part number, it looks like the year date code is visible... its the round stamp to the right of the case part number.
It was interesting to look under my '88 Carrera and '05 GT3 side by side, while not identical the case looks exactly the same. My '05 has a 996 part number case.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-17-2019, 08:27 PM
M96/70641 is a 2001 996 Turbo, 414hp engine. Nothing that unusual about it.
Old 09-18-2019, 04:33 AM
bgyglfr's Avatar
Ok. It sounds like it’s settled that it’s an early 996 turbo case. IS it worth anything?
70T 2.7RS spec.
68L coupe
Old 09-18-2019, 07:47 AM
bgyglfr's Avatar
Should I just make a coffee table out of it?
70T 2.7RS spec.
68L coupe
Chain fence eating turbo
It absolutely is! Structurally, it's probably ok. Some light welding and grinding IMO is all that is needed.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-18-2019, 11:17 AM
