Learnin' to wrench
Thanks so much, darrin, super helpful. Guess I should run a search myself next time!
Still here
![]() PMAX -- try this thread Need Alternator Shop in SF Bay Area BTW, I've used google to find these (using the search "porsche alternator [cityname]") -- pelican posts came up in first page of results |
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 05-27-2020 at 06:51 AM.. |
I continue to be pleasantly surprised at the number/nature of small business that continue to exist just off our collective radar. |
El Duderino
Look around... they are there. Sometimes it's part of a larger business. You know there are other things besides cars that use alternators, right? There is a shop right down the road from me that rebuilds alternators, starters, does small engine repair, etc.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
New-ish 911SC Targa Owner
Every city has one or two. I'll explain our shop here in Richmond and you guys can compare it to yours and see if they are long lost brothers:
Very dirty run down shop with 1 or 2 bay doors and a small "waiting" area. Guy that runs the shop is part genius, part crazy possibly homeless middle aged guy. Not exactly an inviting personality but not directly rude either. Wearing the same pair of coveralls for the last 6 years with only a few wash cycles ever thrown at them. His hair is unkempt and greasy and his fingernails uncomfortably long and quite filthy. He is standing in the only part of the shop floor that isn't covered by the huge pile of old starters and alternators. There are literally thousands of them all over the floor. Sound like your local guy? This is an actual photo I took when I visited the alternator/starter repair shop in my town:
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Learnin' to wrench
Now the fan housing . . .
So I ordered the VR, pulled the fan housing . . . and discovered the housing is cracked. I assume these are not superficial or something I can just ignore?
![]() ![]() ![]() Based on what I've read elsewhere, I think I'll just nut up and pay for a new AL housing so I don't have to worry about fragile magnesium. Better to cry once. I also discovered that the air guide that sits behind the alternator is cracked and was repaired with (maybe) an epoxy of some kind? Any opinions on whether you'd trust that or just replace it while everything else is out?
78 911SC w/ 3.2l swap; 15 BMW m235i |
Stresses placed on the fan housing are usually due to.... an overly taut drive belt tension.
As for the air guide, I’d repair by adding some FG reinforcement. It’s only touched by airflow and indirectly by excessive rotational vibration. Sherwood |
Learnin' to wrench
Yeah, I was kind of surprised when I pulled the drive belt nut that all 6 of the shims were on the outside of the pulley half, which as I understand means that the belt is maximally tight.
Learnin' to wrench
And Finch's is definitely a long-lost brother of your guy in Richmond:
78 911SC w/ 3.2l swap; 15 BMW m235i Last edited by jpr2013; 06-08-2020 at 06:41 PM.. Reason: Edited to add some detail. |
Learnin' to wrench
After getting the new housing and the old fan coated, I finally got everything reinstalled today and fired up the car. Voltmeter shows pretty consistently right at or below 14v, so all is well! Thanks to everyone who chimed in!
