Injector connectors
I'm working on some harness repairs for my 3.2. Does anyone know a good source for the injector connectors? Or a new harness if that's easier, open to ideas.
I believe they are called AMP Junior connectors.
Eagleday has the connectors.
Timmy2 built me a new harness when I discovered that my injector wires were worn through and shorting to the fuel rails. |
Thank you!
PM me, I have the connectors or I can make a new harness if needed.
Search for "Junior Power Timer" connectors. (Sometimes listed as JPT) They are available with more than just two connectors so you need to look to make sure you get the right ones. Usually they come in separate pieces: the connector body, the individual contact pins, and the seals.
Last time I picked some up I got them from either TE or Mouser. |
| All times are GMT -8. The time now is 02:11 AM. |
