-   -   Passenger Side Power Window no workie. (http://forums.pelicanparts.com/porsche-911-technical-forum/1040375-passenger-side-power-window-no-workie.html)
sjanes 09-17-2019 08:30 PM
This is on a 87 911.
The driver side window works fine. I replaced all three switches with new ones. I took a multi-metre to the passenger switch and both blue wires and both red wires have 12V.
Is that normal? How does this switch work? I looked at the wiring diagram in the Bentley manual and I don't understand why they have power with the switch in the neutral position. When both blue wires are disconnected from the switch, they both have 0V, but when I connect one, they both have 12V.:confused:
I was going to take the motor out, but the instructions say to lower the window mechanism, but without power, the window is stuck up.
Any ideas?
Stacy
dannobee 09-18-2019 03:25 AM
It's probably the motor. Whack on the inner door panel a few times while operating the switch. If it works, keep cycling it until the brushes reseat against the commutator.
sjanes 09-18-2019 06:00 AM
Thanks. I have the door card off, so I can whack on the motor itself.
I've read in some other threads about a Torx bolt that can be used to manually wind the window up/down but I don't see it on this car, so maybe introduced in 89?
AG81 09-18-2019 07:14 AM
Stacy
Me too.... pretty common I hear. I plan on taking a wack at it tonight. By wack I mean a hammer to the motor case.
86 911 Targa 09-18-2019 01:08 PM
P/w.
http://forums.pelicanparts.com/uploa...1568840827.jpg
http://forums.pelicanparts.com/uploa...1568840847.jpg
http://forums.pelicanparts.com/uploa...1568840866.jpg
Pics from our '86.
Best,
Gerrry
86 911 Targa 09-18-2019 01:14 PM
Ckt
http://forums.pelicanparts.com/uploa...1568841138.jpg
http://forums.pelicanparts.com/uploa...1568841158.jpg
http://forums.pelicanparts.com/uploa...1568841240.jpg
You will need to cut & paste the factory manual.
Best,
Gerry
sjanes 09-18-2019 06:57 PM
Thanks Gerry. By looking at that wiring diagram, it looks like 12v on the blue wire with the switch in the neutral position is correct.
I tried whacking the motor, no love. Looks like the motor may be kaput. :(
76FJ55 09-19-2019 05:47 AM
Have you verified that the brown wire has good connectivity to ground?
sjanes 09-19-2019 05:53 AM
I tested the power on the red/blue wires using brown as the ground for my multimeter. Is there a different test I should do?
AG81 09-21-2019 01:26 PM
Both switches replaced......a few light wacks of the hammer on the motor case and the passenger window is good to go........ Super happy.....
shuzboomer 09-21-2019 04:42 PM
I have an issue related to ground; my driver side switches don’t work.
If I hard jump them to the door frame, everything works just fine.
I am very confused!
RBL
