911 2.4 Fuse references
Hello all
I'm loking for the original values of each different fuse in a 911 2.4T (carbs) 1973: Fisrt fuse box in the front boot second fuse box in the front boot Third fuse box in the engine compartment I particulary look after the values of the box of 3 fuses link with the ignition system. Thank you in advance for your help...;) |
Looking in my Technical Specification Book:
http://forums.pelicanparts.com/uploa...1569028235.jpg I found this chart: http://forums.pelicanparts.com/uploa...1569028282.jpg You should consider getting a copy of this handy book. |
Thank you Harry for your answer...
As the cap of the fuse box in the engine compartment has been loosed I'm a bit lost... :confused: could somebody give me the values : First one (down the fuse box) second one or midle third one at the top near the boot lid Thank you again http://forums.pelicanparts.com/uploa...1569083407.jpg |
25, 8, 5 top to bottom. As listed in Harry’s post.
Fuse 3 is on top, don’t ask why, it is what it is. |
| All times are GMT -8. The time now is 08:13 PM. |
