what lube do you guy's use on the shift rod bushing
Replacing the shift rod bushing while installing a Wevo shift lever. What lube (if any) is the suggested lubricant would you use?
As I recall I believe I used a dab of white grease
Ernie |
White.
I've been using plumber's faucet grease to minimize the potential damage to the plastic bushings.
| All times are GMT -8. The time now is 01:03 AM. |
