Quick one: breather hoses to oil tank (2.7 & SC era)
Can someone set me straight on where on the oil tank the main crankcase breather hose mounts? Is it on the oil filler neck, or on the upper tank fitting? Car is a '75 911S
And what's the other one? I know, I should have taken a few more pictures during the engine pull.
Thanks!
Old 04-25-2003, 10:47 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
mine was mounted on the filler neck...but that engine is gone now!
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 04-25-2003, 10:50 PM
Thanks K9. Where's the other tank breather connection go?
Old 04-26-2003, 09:03 AM
Upper fitting (one closest to oil cap) attaches to passenger side of airbox using the hose with the a spiral twist in it. The lower fitting on the oil tank attaches to the engine breather (top of engine breather) hose. Jim
Old 04-26-2003, 09:23 AM
Thanks guys.
Colin
Old 04-26-2003, 11:10 AM
jwetering's Avatar
Sorry to beat a dead horse, but K9 and JimSims contradicted each other and I'd like to clarify. I'm trying to figure this same plumbing out because after my conversion to webers, the lower tank vent spews oil all over my engine compartment, while the upper vent (in the filler neck) is attached to the engine case breather. I was thinking to attach the engine case breather hose to the lower vent and put the little K&N filter on the filler neck breather. Am I "allowed" to do that ?
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 04-27-2003, 03:49 AM
Montana 911
k9handler's Avatar
Jim is correct, just wording on my part was bad.
H.D. Smith
2020 Yamaha YFZ450R
Old 04-27-2003, 04:46 AM
Crusty Conservative
silverc4s's Avatar
Jasper,
Your solution will work, unless you have smog testing there - and then only if the inspector knows / notices the open air breather...Good Luck;-)
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 04-27-2003, 08:12 AM
Case breather options ?
A friend of mine put filter on the end of his case breather tube and closed off the hole on the oil filler tube. does this affect the vacuum of the engine ? Any other issues to consider. I get a lot of foamy junk in my oil filler tube. Yuk. I only get 40 minutes each way in the car and the water is not getting out.
Old 05-05-2003, 06:50 PM
SteveF_911's Avatar
I have Webers with watershield air cleaners
Lower tube goes to the crank case vent and the upper one goes to a K&N breather.
66 911 with S engine
2008 Westfield XTR2
Old 05-06-2003, 08:16 PM
I'd suggest installing a catch tank of some sort between the oil filler tube and the breather to catch/separate oil from vapor. I also suggest returning the blowby into the intake after the catch tank for environmental purposes. You can use anything; from a fancy $100 spun aluminum tank to a used windshield washer tank from your local bone yard. Connect with PCV fittings and hose from the parts store. I've seen track cars with the breather tube pointing into a 12 oz. plastic Minute Maid bottle. It's your car. Make it as nice and functional as you'd like.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-07-2003, 12:24 AM
do you mean PVC pipe or is there a PCV filter of sorts.
I like them I drive them
Old 05-07-2003, 08:26 AM
s_wilwerding's Avatar
PCV stands for positive crankcase ventilation. It's a valve that allows air into the crankcase.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 05-07-2003, 08:28 AM
911s don't use a PCV valve which normally vents crankcase pressure off idle into the intake. On our engines, it's just a breather hose that normally goes to the air cleaner. The blowby from the crankcase (unburned hydrocarbons) is mixed with oil vapor (sometimes a lot). At high speed and if the oil tank is full, oil mist will finds its way out of the oil tank which ends up dripping on the ground (and engine) on its way out. Racing organizations frown on oil on the track, thus the need for a catch can.
Sherwood
Old 05-07-2003, 09:52 AM
how about this. Take the crank case tube directly to the air intake to eat up thase fumes, then take the oil off to a catch can with a vent. I would suspect that the oil does not fume much and this would allow for the water vapor to get out.
Old 05-07-2003, 12:15 PM
The oil breather tube carries both oil fumes and fuel vapors which should be separated otherwise the engine ingests oil. I can't think of an easy way to separate the two inside the air filter housing.
Sherwood
Old 05-07-2003, 05:28 PM
