broken key
was going to let a porschephile friend drive and he broke the key off in the ignition! Had just lost my good key and hadn't gotten a new one made yet, this was my old spare. Rotten luck!:mad:
Can crank the car with a screw-driver. Any advice? |
try hemostat Worked for me .
Two sturdy hat pins top and bottom and lever it out.
Strong magnet? Worst case get a locksmith to come to you. I wouldn't mess around with a screwdriver. It will cost you a *****load of $ if you mess up the cylinder.
Jason |
Thanks gentlemen. Appreciate your suggestions.
Hat pins ... don't have any, let alone a sturdy one. Don't have a hemostat either for that matter.
OP, Is the key broken completely flush ? No stub to grab on to ? |
Finishing nail would make a good hat pin for me. Grind/file if needed.
Haven't tried it yet, but I got some of that super glue that cures instantly with ultraviolet light. Would be interesting to see if that had enough strength to do a temporary bond. Couldn't be sloppy in applying it, of course.
Dentists have used this UV curing cement for crowns, etc. for quite a while.
Would need an instant bond to try to pull the stub out. |
| All times are GMT -8. The time now is 06:29 PM. |
