-   -   What does this plug connect to? (http://forums.pelicanparts.com/porsche-911-technical-forum/1040790-what-does-plug-connect.html)
kltarga72 09-22-2019 07:31 PM
Getting ready to reinstall the engine in my 1980 SC. Making a check list for all electrical and fuel line connections that need to hooked up as I reinstall the engine. I cannot figure out where this two prong connector goes. It is on the left side of engine, one brown wire and the other is red/white. It looks like it goes to the other side of engine to the supplementary air valve. Looking in the Bentley Manual page 970-8 lower right corner it shows the valve with the same colored wires.
So where on the left side of engine bay does it connect to???
I was going to make a continuity check at the valve but was not able to disconnect the plastic plug from the valve, did not want to break the plug. http://forums.pelicanparts.com/uploa...1569205733.jpg
http://forums.pelicanparts.com/uploa...1569205823.jpg
timmy2 09-22-2019 07:37 PM
Not used after ‘79 on US models. Just tape it up and tuck it out of the way.
kltarga72 09-23-2019 07:35 PM
timmy2
Thanks, after looking at the cable closely I could see where it had been folded and wire tied. Must be the mechanic that did a top end job cut the tie.
Lash
timmy2 09-23-2019 08:04 PM
Factory just covered the terminals with tape 0n the flats, then a wrap around to secure the tape, then tucked them out of the way.
911tracker85 09-25-2019 06:51 AM
as I was helping a friend resurrect his 84 944, commented that he will occasionally find connectors not plugged into anything. they may be for things / features your car does not have. as long as all the major things work.
carsinc 09-25-2019 08:36 AM
Wire plug
Could be plug for remote voltage regulator which was used on early CIS cars. Later Cis cars voltage reg. were integrated.
timmy2 09-25-2019 08:44 AM
Dan, it is used on 78/79 SC’s (and ROW cars after) for the vacuum time delay switch.
80-83 Lambda cars didn’t use it, but Porsche only built one engine harness for all SC’s with Lambda or without Lambda.
911 SLANT 09-25-2019 08:52 AM
Looks like the Blower motor plug
timmy2 09-25-2019 09:00 AM
It’s not....
theiceman 09-25-2019 09:16 AM
goes here on early CIS cars ( mine is 78 )
https://i.imgur.com/mvS34Kf.jpg
