fuel pump outlet what M size ? 1988 3.2
Hi,
searched the forum a bit but could not find the answer I needed...
does anyone know what M size the outlet is of my 1988 3.2 ?
it's the thread with the hole, where the banjo bolt is attached...
is that an M12 x 1.5 ?
many thanks
gr
Old 12-28-2023, 08:42 AM
Looks to be.
The Bosch Cross Reference/Universal Fuel Pump document shows 0.580.464.069 for your 3.2:
Supercession table has no entry for that pump - not superceded means original part # still valid.
Specs for that pump are here:
'77 S with '78 930 power and a few other things.
Old 12-28-2023, 09:08 AM
Thank you !
that is indeed a very complete answer to my question,
many thanks.
Reason for asking is that I'm investigating the cost to switch fuel lines from metric over to the AN standard - when checking the forum, I did not find someone who did that before, and the metric sets available are expensive...
the AN allows you to do it yourself at a fraction of the cost of buying a set
still in investigation mode, when installing I will make up a detailed description of what I bought and how well it went...
best regards
Old 12-28-2023, 10:50 PM
