Install ZF 964 turbo LSD to 911 3.2 G50
Hi, my name is Shinji, Japanese 1987 911 owner.SmileWavy
I got ZF 964 turbo LSD (genine) and tried it to install my 911 3.2 NA with G50. After the LSD installation, when I rotated a joint flange, I could not rotated it (It was completely fixed) When I loosened transmission cover bolts a little, the flange was rotated well. I again removed the LSD and checkd sims and bearings but these were no problem. I thought ZF 964 LSD fits 911 with G50 mission.:confused: Do I need to replace sims and adjust backlash? Could you give me some advises? I hope I had some mistake... Thanks, Shinji, Y |
You absolutely need to reset the backlash. The ring gear flanges aren’t the same thickness. This is why there are two different length ring gear bolts.
Hi Matt san,
Thanks for your advise. I will try to reset the backlash this weekend. Thanks, Shinji, Y |
| All times are GMT -8. The time now is 09:39 AM. |
