lifting the car
1987 carrera,
I am going to perform a full tune up including valve adjustment. After removing the oil and filter the night before, The rear of the car will be lifted and jack stands placed under the torsion bars on both sides. my question is: What is the best way to secure the car from rolling off the stands? (wheels were taken off).
Also...I saw some pictures of people placing the wheels underneath the car...just in case...where should the wheels be placed if this is advisable?
Old 09-29-2019, 05:13 AM
If the front of the car isn't up in the air, simply chock both front wheels fore and aft.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-29-2019, 06:00 AM
If the worst should happen, and the car’s jack stands fail, the wheels under the car will prevent the floor of the car hitting you if you are under the car at the time. Or at least, only squish you a little, not flat.
It is just a belts and suspenders approach.
43 Year member of the Porsche Club of America
Old 10-01-2019, 02:04 PM
82 911 SC - Ancora Imparo
If the car is not level (or close to it) will you still be able to drain the max amount of oil out?
Ethan
P-car: 1982 911 SC - Wine Red Metallic Coupe PB&J
Murica: 2017 Corvette Z06 - Watkins Glen Gray Metallic
Old 10-01-2019, 02:17 PM
lifting the car
I was going to drain the oil prior to lifting it...flat surface. then lift the car from the back with my hydrolic jack and post the 2 stand jacks, liftimg the car approx 6 inches. this will provide me additional height to more comfortably do a valve adjustment. (front wheels are on the ground)
my question is: what is the best way to secure the car from rolling off its stands?
Old 10-02-2019, 05:29 AM
a.k.a. G-man
Geronimo '74's Avatar
lift the front as well
Geronimo
32C Member #41
1986 911 3.2 Carrera (not stock)
1974 911 2.7 9114102230 SOLD
Old 10-02-2019, 06:11 AM
carreradpt's Avatar
Chock the front wheels and place the rear tires under the car just in case. Drain the oil with the car on the ground first.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 9's, Steve W chip
Kuehl AC and fresh top end
Old 10-02-2019, 10:00 AM
lifting the car
I do not believe that lifting the front makes it safer and secure from rolling over...
Old 10-02-2019, 10:02 AM
a.k.a. G-man
With for wheels off the ground, it will not roll.
You can push it off the stands, but it will not roll off.
Geronimo
32C Member #41
Old 10-02-2019, 10:58 AM
New-ish 911SC Targa Owner
pampadori's Avatar
I'm not much of a safety nanny, so that might be to blame...you aren't going to easily get the car to roll off the jack stands if you are using the torsion bar caps and jack stands that have a \__/ shape pad.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 throttle bodies, B&B headers, Dynomax muff, Fidanza FW, Alum PP
'05 E500 wagon in minty cond
'13 Volvo XC60 (hers)
Old 10-02-2019, 11:39 AM
Sboxin's Avatar
. . . Picture worth a 1000 words . . . and, "What, me worry . . ."
Engine drop with jack stands on rear torsion bar caps and front tires on 4" wood blocks .
My son and I have done this several times before buying the Quick Jack . . .
Wish you the best on your projects,
Regards,
Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 10-02-2019, 12:00 PM
speednme1's Avatar
Working in the Chemical field for over 25 years, safety is our priority above anything. Fortunately I have used some of the safety methods I have become accustomed to and have applied those to working on my car and home. So become a “safety nanny” my friend and save yourself a boatload of medical bills..lol
Rey....77 930 "the Mistress"
Old 10-02-2019, 01:23 PM
