speedracer92's Avatar
Rear seat belts won't extend - seem stuck
Want to install some rear 3-point seat belts in my 87 Targa as the PO didn't have them there so I don't know what they looked like. I have these from a 964 that appear to work (was going to see if rear shelf will accommodate them as they are slightly different than the schematic in the manual).
However, I can't get the belt to extend out. What you see in the pic is the most that will come out but it definitely has more webbing left on the length. I can't figure out what is stuck.
Anyone have ideas or had this issue before?
Todd
1987 911 Carrera Targa
Old 10-20-2019, 03:06 PM
skinnerd's Avatar
The retractor body usually has to be exactly straight up for the seat belt to come out. If it's at any kind of a oh-so-slight angle.....no luck.
Try that.
It worked for me when the same thing was happening on a new set of retractible seat belts.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 10-20-2019, 03:48 PM
Earthling
Brian Cameron's Avatar
Install them, just takes a few seconds,
Pull on the belt with all your might for a second then let go. Then try pulling out slowly and gently. Might take a couple of tries.
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 10-20-2019, 08:46 PM
Thanks will give those a try in a few days and report back.
Todd
Old 10-21-2019, 01:00 PM
High Life's Avatar
Try that.
THIS..
I replaced mine.. has to be at a certain angle and pull nice and steady - not fast.
1981 911SC
Old 10-21-2019, 01:05 PM
