| SkiVT |
11-21-2019 12:25 PM |
Take this with a grain of knowledge salt as my experience is limited to 4 years ownership: I am not sure the 2000/800/2000/950 is materially far from normal. Mine basically does the same pattern but at 1700/800/1700/950. I think that initial rpm drop is simply the fact that the air supplied by the AAR takes several seconds to have its desired affect as the fuel dumped by the CSV burns off. If you want your rpm high point to be slightly lower I believe you can adjust your AAR so that the air opening isn't quite as big at cold start (lots of threads on that process). I think Tony has stated that the normal initial rpm drop should not go below warm idle of 950 so you are very close to "normal". Overall my thought is simply the electrical/heat influenced helpers/regulators (TTV/AAR/WUR) all had designed coordination by the Porsche engineers. Since it's not modern EFI, these components all work but the exact timing across all ambient temperatures at cold start isn't always perfect/consistent. It also seems varies further as the components age.
Maybe a bit more on the WOT afr issue would help. Is it dropping to 12.5 and then rising to 15 while at WOT? or going from 12.5 to 12.8/13.0? If it's not dropping from your 13.5 idle to something lower, then the vacuum assist isn't working so look there. If it is dropping and only rising slightly, not sure it's an issue at all. If it's climbing to 15 at wot, you got an issue.
Like your AFR gauge placement. I find my a bit tough to see down there but overall I like it being out of the way but still usable when I am curious.
