Help! Sticky gum from tree
Can anyone help with advice to remove a blob drop of sticky sap from a tree?
Jack K 97 993 TT 82 SC Targa [yep, bought it back ]Previous - 97 993 2S; 89 Carrera; 82 SC Targa; 66 911 |
Some kerosene dabbed on a cloth will remove it, then wash/wax afterwards.
gary |
You need a tar/wax remover. One Grand and Wurth make good products, as does 3M. I can't find the really great 3M solvent in the US anymore (it's probably lethal or something), Turtle Wax makes some stuff that barely works. You might try a citrus based degreaser as well.
But once you use any of these things, you need to cover the area back up with wax. At least it is tree sap. The stuff that comes out of birds is nearly toxic to paint.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
If you are concerned about damaging the paint, you might try the Avon product "Skin So Soft" before resorting to one of the solvents suggested above. It sounds strange, but it works well and might be worth a shot.
Good luck!
Remember our friends: Warren, Ron, Grady, and Steve. 76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster |
Automotive Monomaniac
Try WD-40. The stuff takes many different things off, and is apparently harmless to paint.
Last summer, I drove to Arizona in my new Passat. Somewhere... I hit some gum with my front tire. It spun round and round and the resulting 'web' was all over the side of my car. To make matters worse, blowing sand stuck to the gum as I continued my drive. Once home, I took a can of WD-40 and sprayed the side of the car. Then, I used a soft rag and slowly worked the gum off. It came off cleanly. Afterwards, some good wax and the doors were like new!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
WD-40.... this stuff works great for many uses.
Calspeed
2008 Porsche 911 Turbo - One of the Baddest 997 Turbo in the SF Bay Area 1985 Carrera Cabriolet - The 2nd Baddest 911 Cab in the SF Bay Area. (sold in 2006) |
Yes, "Off" would be perfect trade name for such a product Michael!
Thanx for the suggestions.
I've been told bya technical person at BP petroleum to use white spirits. He seemed quite confident.
white spirits? Is that what we call kerosene? BTW, kerosene is the primary ingredient in most of the "tar removers" on the commercial market...
White Spirits isn't kerosene. The guy I spoke to at BP didn't like Kerosene ... he said it would leave a grease mark which would have to be carefully cleaned and polished and may take off a bit of paint.
Still have to buy the white spirits.
If "white spirits" is what we call naptha here? Then you're talking lighter fluid, aka coleman fuel. Either one is harder on paint than kerosene or WD40, which also removes pitch (aka "sticky sap") well. (BTW, those who still use a zippo lighter? Coleman fuel works well as lighter fluid, and sells for much less per ounce.)
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 02-10-2003 at 09:00 PM.. |
The plot thickens ... the guy at the hardware shop said exactly what pwd72s said. Both kerosene and white spirits are dissolvents and far, far too strong to use on the car's painted surfaces.
He suggested using a more natural product, like natural citrus based De-Solv-it or eucalyptus oil. Alternatively a little methylated spirits - which is what I eventually tried. It came off easily enough, wash and polish and pretty well near perfect. If I look real close I can see the slightest mark but no on is going to pick it - not even me once I forget where it was.
I picked up a can of the 3M Tar, Adhesive & Wax remover at Schucks this weekend. I used it to remove old weatherstrip adhesive. It was $7.50 for a little can. Jeff |
Go to your local paint store and pick up a can of PPG "Acryli-Clean". It's safe on paint, and will remove almost anything.
I use a product called "sticker shock". It comes in a spray can at local auto part stores. It is designed to remove bumper stickers. It also works well on 100 deg. chewing gum. Trust me...
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
"Goof Off"
I've used it on many items like this. Including dried adhesive on my black BMW. Totally safe! |
Having tried most of the produts listed here, I can say that most of them are either pretty harsh or don't work all that well for removing the blobs of sticky sap. When i did detailing the one thing i found to work really well was the citrus cleaner, made by Stoner. I'm not sure who sells Stoner products, but the stuff is killer... Its an aerosol, just spray a little on a towel, and it'll take off most any sticky substance on your paint. Plus it doesn't leave any greasy residue or anything either.
WD-40 or Wonder Mist
Used them many times and they work great! I've been paranoid about my cabriolet top though??? So far, so good.
Rob McKibbon, Shuswap Boy <>< To steal ideas from one person is plagiarism, to steal ideas from many is research. Currently researching ideas for my '74 911 Cabriolet |
