3rd brake light installation
Hi guys,
I followed the steps on the DYI 3rd brake light installation and wanted to share the results! So far it works great and I feel a lot safer.
I ended up using the following LED Third Brake Light Strip:
https://www.amazon.com/dp/B07MH52CMY/ref=cm_sw_r_cp_api_i_7G.KDbBMNMJP4
The strip was 36 inches long, so I ended cutting it down to 32 inches. I ran the wires along the left of the car, underneath the rubber on the window. No cables can be seen.
Pics below:
Old 10-01-2019, 06:09 PM
Perpetual Reassembler
2jmotorsports's Avatar
That is a pretty cool unit. Let us know how well it holds up over time.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 10-01-2019, 06:20 PM
Mark Salvetti's Avatar
That looks really cool (and cheap!). What about that black block in the wiring, were you able to tuck that away too? And you just used the double-sided tape to fasten the light?
Thanks!
Mark
1979 911SC Targa
Old 10-01-2019, 06:45 PM
Vintage Owner
Jack Stands's Avatar
Mounting a third brake light is probably a necessity these days if you’re driving in city traffic. Looks great!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-01-2019, 07:22 PM
Still here
pmax's Avatar
Well done, FIFY
Old 10-01-2019, 07:27 PM
Thanks!
Mark
The black box in the wiring ends up in the engine compartment. You can achieve this by cutting the wire and passing it through the hole on the left side of the window and then reconnecting the wire. yes, just used the double sided tape that came with the strip.
Old 10-02-2019, 02:25 AM
Formerly known as Syzygy
Canada Kev's Avatar
How is its brightness?
Kevin
Old 10-02-2019, 04:54 AM
carreradpt's Avatar
Viczeva, did you have to remove your back deck to get the wire into the engine room?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 10-02-2019, 10:04 AM
freesaints's Avatar
And how did you cut down the light strip? Did you just cut it or is there something more that you need to do?
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 10-02-2019, 01:25 PM
Diss Member
Quicksilver's Avatar
What does it look like when it is turned off?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-02-2019, 05:36 PM
It would be great to see a picture in the daylight to see details of the installation. I'm not clear on how the wire get's to the engine compartment if the lights are mounted on the outside.
Adam
Old 10-02-2019, 06:08 PM
No. There should be a small hole on the driver side of the rear window. It helped to put a flashlight on the inside of the car pointing at the lower corner. you should be able to see the light shine through when you open the engine deck.
Old 10-02-2019, 10:17 PM
I just cut the plastic casing with a razor (extremely easy), and then with folded the exposed LED strip into the plastic casing. The back of the plastic casing is black, so the LED does not shine through. Very simple process.
Old 10-02-2019, 10:19 PM
Adam
Lights are mounted on the inside.
Old 10-02-2019, 10:20 PM
When its turned off you cant tell its there. Now, i haven't taken her out on a clear sunny day yet, so it might show a lot more in direct sunlight.
Old 10-02-2019, 10:23 PM
911SC Tinkerer
merlinfe's Avatar
Great Job! Hopefully you'll wake people up from their cell phone induced zombie state while driving.
- Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 10-03-2019, 06:15 AM
With lights off.
Old 10-03-2019, 06:05 PM
