Hbrand
hbrand's Avatar
1967 Porsche 911 SW Targa Engine number missing
1967 911, Vin is 500088, Color is 6606, original Mileage 69754, Webers
Engine number according to 911 Service booklet is 911364, Sept. 1967
Fast forward to 2019: We found no engine number, no type number,
nothing grinded of.
There are service and repair records but nothing regarding engine failure - swap.
Guess if it has been done under warranty, there would be no bills.
Upon engine disassembling, all head's read 6-66 and with bad exhaust guides.
So if this is a replacement engine - the original engine must have had a catastrophic
failure very early on, possible in 1967 already.
Is that possible ?? What are you thinking ??
Greetings, Harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 09-29-2019, 06:56 AM
joegt3cup's Avatar
You need to get a kardex, if it was done under warranty it may be noted there.
Joe
Old 09-29-2019, 09:56 AM
djpateman's Avatar
If it was done under warranty, then the case would be numbered. It have have an AT# or a KD# if replaced formally. This does sound like a replacement case done outside of warranty. On aluminum cases look for the casting dates under the pulley; this will provide an indication of the replacement date.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-01-2019, 05:40 AM
Hbrand
hbrand's Avatar
Engine without number
Turns out the blank engine case date is 65, all other parts are 66.
What is the difference in the blocks 1965 to 1966 ?
Greetings, Harold
Cheers
1969 Mercedes 280SL
Old 10-01-2019, 09:19 AM
Hbrand
hbrand's Avatar
Kardex for 1966 Porsche
Kardex
Cheers
1969 Mercedes 280SL
Old 10-08-2019, 06:13 AM
Fleming's Avatar
Google word translation came up with this:
Naue DelrinLagerschole eingb.AM111WG.66
"Neat Delrin storage rack eingb.AM111WG.66"
Without speaking German - Can I be reading that as a "storage shelf engine from 1966" ?
Old 10-08-2019, 01:07 PM
Hbrand
hbrand's Avatar
Engine
This German wording means:
Delrin main bearings installed.
Well for this the engine needs to be completely disassembled. Maybe they found
a casting problem with the case and to be save used then a case they had in stock.
Working on engines myself, I would have done the same.
Greetings, Harold
Cheers
1969 Mercedes 280SL
Old 10-09-2019, 05:04 AM
