86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
oil line.
Wrench size please.
Thanks,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-10-2019, 10:10 AM
proporsche's Avatar
36mm........
1985 911 with original 494 340 miles..s..795 563 km
Old 10-10-2019, 10:14 AM
Check your local bicycle shop. They have thin 36mm wrenches.
77' Targa Narrow Body
Copper Brown Metallic
3.0 from an 82 SC - love that SC power
Old 10-10-2019, 10:32 AM
New-ish 911SC Targa Owner
pampadori's Avatar
https://www.pelicanparts.com/More_Info/PELPWOLW.htm?pn=PEL-PW-OLW&gclid=Cj0KCQjwrfvsBRD7ARIsAKuDvMM2jjyGA3InubAa5Sxr cjG-oOpn74co-lOCaEsYxrMqQy3fZhTAu38aAtnOEALw_wcB
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 throttle bodies, B&B headers, Dynomax muff, Fidanza FW, Alum PP
'05 E500 wagon in minty cond
'13 Volvo XC60 (hers)
Old 10-10-2019, 12:41 PM
Wrench.
Thanks all for your comments/help.
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-10-2019, 12:59 PM
Uncertifiable!!!
Uwon's Avatar
I bought a cheap 36 mm combination wrench and ground off the end just enough to fit over the pipe.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 10-11-2019, 05:03 AM
BoxsterGT's Avatar
Porsche Crest
Always tough getting these apart. Most are frozen from Steel-Aluminum dissimilar metal electrolysis or just plain rust.
Yours looks pretty clean, you may get lucky and it comes apart without issue.
Most important is to use "Anti-Sieze" paste on the threads when reassembling.
Len
Old 10-12-2019, 01:53 AM
Disimilar metals.
You are correct.
The dissimilar expansion values can be an issue.
The line started leaking for no apparent reason.
I may just move forward with uwon's idea
if I can find a short 36mm wrench,
or just cut one off to the desired length
as there is not much room to swing a wrench
at that location.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-12-2019, 07:51 AM
It is 36mm but you are right that there is not much room for a wrench. Many people remove the entire unit with lines and all then bring it to a bench to remove the lines. Some even ended up cutting up the nut to get the line off. Good luck.
Porsche 2005 GT3, 2006 997S
Exotic: Ferrari F348TB Factory Challenge, Ferrari 328 GTS
Disposable Car: BMW 530xiT, Audi A3S
Old 10-12-2019, 08:39 AM
Diss Member
Quicksilver's Avatar
The difference in expansion rate isn't the issue.
The problem is the galvanic corrosion from the difference in the anodic index of the of the dissimilar metals.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-12-2019, 02:38 PM
Harbor Freight has a set of metric "service wrenches" that work OK for this. The handles are short but you can slip a piece of pipe over them for extra leverage.
Old 10-12-2019, 02:53 PM
Wrench
OEMTOOLS 22133 36mm Jumbo Combination Wrench (Amazon)
Thanks to all who responded.
I just ordered one of these & will
modify as per member Uwon.
and shorten to accommodate the
available adjustment space.
1986 911 Targa.
Only in L.A.:
Old 10-12-2019, 09:12 PM
Uncertifiable!!!
Uwon's Avatar
That is why my cut wrench works in that tight space. You have several additional positions.
Johan
Old 10-13-2019, 06:11 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey Dr Gerry,
You can borrow my oil line wrenches :-)
Just let me know,
J
The trick is holding the thermostat housing in place while you tighten, I got you covered for that too :-)
'85 Carrera Targa
PCA/POC
Old 10-13-2019, 10:46 AM
Wrench.
Originally Posted by DRACO A5OG View Post
Hey Dr Gerry,
Just let me know,
J
Hey Jim,
I just bought one as per member Uwon's suggestion.
I'll have to cut it down.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-13-2019, 10:48 AM
Another reason for complete removal. There’s also the issue of reinstalling/threading the nut back on. Two flexible ends are easier to align; less chance to crossthread the relatively fine threads.
Old 10-13-2019, 11:00 AM
