Dave Ploss's Avatar
Cool Cleaning Rust off fittings under the Car
The suspension and brakes are going together this weekend but there are rusty and dirty fittings on some of the oil lines and fuel pump (?) lines under the car. What is the best way to remove the rust, get the fittings sparkling clean (Not really) and keep them from getting crappy again?
I'm using a wire wheel to get the rust off but in the RR wheel well and near the fuel tank in the front, there are parts I can't get to real well.
Thanks.
Dave
Dave Ploss
'87 911 Carrera Coupe - Black
'90 Mercedes 190E
'00 Filippi Lightweight Double
Old 04-04-2003, 06:55 AM
Certified Pre-Owned
BGCarrera32's Avatar
Hmmm...trying to do it without removing the lines and fittings will largely be a pain. You could try a scotchbrite pad...
Removing and replacing anything that has to do with fuel would be advised. If they are really rusted that bad then the hoses are probably in question as well. Any brackets you want to clean you could have bead blasted (try the local auto parts store), and I would just replace any hose clamps. Do not try and bead blast fuel line fittings as any glass beads (like fine grains of sand in size) that found their way into the fuel could cause serious problems...
-BG
'84 Carrera Coupe
Old 04-04-2003, 07:05 AM
Heck, I’m only 5 not 71!
targa80's Avatar
I have read that using por-15 metal ready in a small container throw the rusty nuts and bolts in for a day or two and they come out clean. I have not tried it yet myself but will be in the near future. The metal ready can be run through a filter screen and re-used over and over again. Check with the por-15 web sire FAQ section on the metam ready.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-04-2003, 08:46 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Pat,
That's a good tip. I have numerous nut/bolts in labeled baggies that I want to clean up prior to putting everything back together. I was thinking wire wheel, but don't want to strip off the plating. How about soaking them in that gallon carb cleaner solution you can buy at the auto parts store? Anyother good tips?
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-04-2003, 09:02 AM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
I'll post some before and after pictures when I get home this afternoon. Works great.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 04-04-2003, 10:18 AM
HarryD's Avatar
I elieve that POR-15 metal ready is a phosphoric acid solution and will remove the rust but also any plating. Once out of the cleaning solution you need to restore the corrsion protection (plate or coat) to keep the part from rusting again.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-04-2003, 10:37 AM
Stahlwerks.com
jhelgesen's Avatar
The metal ready leaves a zinc phosphate coating on the parts, looks like a greyish coating, after the parts are rinsed. Haven't seen any rust on the stuff I've cleaned yet.
John Helgesen
Old 04-04-2003, 11:09 AM
Certified Pre-Owned
For those of you wanting to get fancy and wishing to drop a little more $, you could buy a vibratory tumbler (similar to a rock tumbler only faster) with derusting and polishing media loaded inside. You can get them from eastwoodcompany.com...I think around $100. Shine up the stuff and then get a home plating kit from caswellplating.com.
I suspect however that this will put a serious damper on the time you have available to actually DRIVE the car...
'84 Carrera Coupe
Old 04-04-2003, 12:18 PM
RallyJon's Avatar
I tried Harbor Freight's $30 rock tumbler.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=46376
Works great removing rust and paint from fasteners, but not so good removing crusty adhesive for some reason. Their so-called metal polishing media is probably inferior to the specific purpose media Eastwood sells.
993 · 911 · STI · S4 · rally car
Old 04-04-2003, 12:31 PM
HarryD's Avatar
I saw that on the MSDS but suspect the coating is pretty thin. Given some of the harshness of the outside environments, I, for one, would add another coating of something (POR-15, cold galvanizing spray, paint etc).
Also, Metal Ready (like many rust killers - Rust mort, naval jelly, etc.) contains phosphoric acid. While it preferentially eats the rust (roughly ten times faster than the base metal), once the rust is gone, it will eat the underlying metal as well.
Harry
2020 MB E350 4Matic
Stahlwerks.com
jhelgesen's Avatar
Good points Harry. It probably would come off pretty easy.
John Helgesen
Old 04-04-2003, 12:48 PM
Evapo Rust
Old 04-05-2003, 01:31 AM
HarryD's Avatar
Originally posted by JasonAndreas
Evapo Rust
Interesting. Didn't know that Stainless Steel can rust though.
Harry
2020 MB E350 4Matic
Old 04-05-2003, 02:00 AM
