Text me.828-230-0788
Joe Bob's Avatar
Another Optima thread....
After 9 months dead, I was finally able to find an old school analog battery charger. After four days of low/hi charging it came back to life. We'll see how long it lasts as it went out of warranty when I was towing it back east and it sat all winter while discharged.
My last one lasted 15 years. I regret having replaced it with the same due to all the bad press Optima has had. But better than dropping three large on a replacement.
Stay tuned....
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 10-12-2019, 03:49 PM
gduke2010
gduke2010's Avatar
I had an Optima go completely dead and put it on a charger until fully charged. But, it wouldn’t hold the charge. The battery was under warranty and the parts store replaced it. Then because the I neglected and didn’t trickle charge the next winter, that one went dead, too. So, instead of buying a new battery, I bought an Optima charger. The charger brought my battery back, and no problems since.
Old 10-12-2019, 05:09 PM
Joe Bob's Avatar
What makes the Optima charger so much better than a regular trickle charger or a standard Sears type charger with he 2/12 amp and start function?
Old 10-12-2019, 06:44 PM
gduke2010
gduke2010's Avatar
It cycles the battery when drained to low. It’s a higher quality charger. I had a Sears charger overcharge a battery.
Old 10-12-2019, 07:13 PM
Joe Bob's Avatar
Did you buy the one hundred bucks one or the two hundred bucks one?
Old 10-12-2019, 07:48 PM
gduke2010
gduke2010's Avatar
I got the more expensive one. It was a few years ago and probably paid less than $200. Anyway, look at them online and in the parts store. They’re good quality and have a lot of features.
Old 10-12-2019, 08:13 PM
Hey, nice marmot.
tirwin's Avatar
I think some of the battery minders claim they have some way of varying the charge that de-sulfates the battery.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 10-12-2019, 08:30 PM
gduke2010
gduke2010's Avatar
See your in N.Carolina, I lived on Lake Norman for a while. It's a beautiful state and my favorite time of the year there was fall. Best time to drive the Porsche.
Hey, nice marmot.
tirwin's Avatar
JB, didn’t realize you had moved. Love Asheville. Lots of great driving!
Old 10-12-2019, 09:02 PM
Joe Bob's Avatar
Actually Ash and Myrtle Beach....
Old 10-13-2019, 04:30 AM
How did the Optima go dead? Optima Reds always need to be 80% charged. Thus if you have a consumer need to use a maintainer with the appropriate AGM setting. I use a CTek maintainer and it works well. My Optimas (2) have several years.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 10-13-2019, 10:48 AM
With the original Optima batteries, a typical battery charger wouldn’t work when fully discharged. The suggested procedure was to charge at a high rate for approx. 30 min., (~50-60A), then follow up with a trickle charge while monitoring battery temperature.
Optimal have good shelf life when stored properly, but use a battery maintainer to avoid self-discharging to below a certain threshold.
Sherwood
Old 10-13-2019, 11:12 AM
