Insanity Check - Door Hinge replacement
Guys, I have been getting the bare tub repainted and am working up to reinstalling the doors into the car.
At issue is that I removed the hinges from the chassis, carefully marking which position each hinge came from, marking which shims were in which location and have now painted all the parts individually.
My thought has been to reinstall the complete hinges into the doors (both halves of the hinge with hinge pin in place), which in my mind ought to be easier since the door will be on the bench.
Then the idea is to just bolt them onto the door post, with the correct shim in the location and theory then was, since nothing has changed in terms of hinge, shims or door post, that I would be left with just the challenge of adjusting the bolts to get the door gap properly set.
The doors are completely stripped so are fairly light...and my esteemed helper, aka my wife...can do the bolt insertion and initial tightening while I hold the door.
Sounds like it will work or has someone tried this and really the only option is to mount the hinges on the body, then drive in the pin with the door in place (feels more dangerous and risks damaging the paint)
Also, I just had the clever idea of replacing all the bushings while the hinges are out of the car, ought to be pretty simple to press them in and then ream with the proper 8mm (or more than likely 5/16") ream/drill. Ought not to change anything ....right?
Comments and addressing the full extent of my insanity much appreciated.
BTW, here is the link to the build thread...
http://forums.pelicanparts.com/porsche-911-technical-forum/185692-fitting-6-speed-g50-89-carrera-new-post.html
Thanks!
Dennis
Old 10-14-2019, 12:37 PM
Dennis,
I just had my driver's door off to get at a few issues. I've had the door off plenty of times, and never removed the hinge pins. I just put a 2x4 under the door and hold it up with the floor jack. Remove the hinge bolts where they attach to the car frame pillar - not from the door. Very easy. No issues. The door goes on and off without any trouble.
Rex
1975 911s and 2012 Range Rover Sport HSE
1962 BMW R50/2, 1995 BMW R1100RS
Old 10-14-2019, 03:49 PM
Originally Posted by Walter_Middie View Post
Dennis,
You know, that's been my thought as well. On my last 911 I pulled the hinge pins off and it was a PITA when I finally reinstalled the door to get the pins firmly in without damaging paint....
Thanks!
Dennis
Old 10-14-2019, 04:49 PM
