Adjustable front sway bar.
Im sure I saw an adjustable front sway bar listed recently from Rebel Racing.Appears to have vanished or as usual im imagining stuff.
Any recommendations guys.Require front set up.1978 3.2ss.Any advantages over stock sway bar? |
check out Tarett Engineering, they sell direct and are available through Pelican. High quality parts. Main advantages over stock is reduced body roll in the turns and easy adjustability to tune the handling.
+1 for Tarrett - they make excellent products. If you're wanting to spend a bit less $, check out Eibach's front sway bar; 3 way adjustable - link below.
Let us know if you have any other questions. Eibach Sway Bar |
http://forums.pelicanparts.com/uploa...1571097391.jpg |
Eibach available from Design911 for UK pelicanites
| All times are GMT -8. The time now is 04:44 AM. |
