Seatbelt Solutions for early SWB 911??
Hi guys,
Wondering what seatbelt solutions are available to early SWB cars that only had lap belts both front and rear from the factory?
Ideally solutions that avoid drilling into the shell!
The lapbelts never make me feel particularly safe and I'd like to use the car as the maker intended!
All ideas and pictures gratefully accepted!
Cheers
Jason
Old 03-14-2013, 04:14 PM
early seat belts wanted
Do you have any old seat belts from SWB ? My car is seldom driven so I'm less worried about a 3 point set up. Old belts are fine if you still have them. Also need the attachment hardware.
Old 10-17-2019, 08:19 PM
HarryD's Avatar
This website may be helpful. https://www.peparts.com/front-seat-belts
The mounting points should be in your car unless you or the PO removed them.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-17-2019, 09:03 PM
