Heater hose
Hello I have a question? do anyone know the heater hose size for a 79 sc with factory a/c I heard it two sizes, and it's very difficult to order, because I can't figure out the right size. it wasn't there when I bought the car. thank you for the help it's cold now.
sylvester
Old 10-17-2018, 04:01 PM
The large tube is 60.mm and small is 50mm using two reducers
I’ll get part numbers and edit
Bruce
Old 10-17-2018, 05:53 PM
Thank you Bruce that's all I need.
sylvester
Old 10-17-2018, 06:28 PM
Coudnt find. Part numbers
Bruce
Old 10-17-2018, 06:40 PM
Bruce
Thank you Bruce I got it.
Old 10-17-2018, 08:02 PM
MBAtarga's Avatar
I'm going through research on the two different hoses. Here is what I've found as the details are not given with the parts descriptions on this site - at least I didn't find them. P/N 91121127400 is the smaller (50mm) diameter hose that is used on cars with A/C and connects at the blower with a reducing collar and another reducing collar at the lower right connection under the A/C Compressor bracket. P/N 91121152200 is 60mm in diameter and is used on cars without A/C. No reducing collars are used.
Mark
'83 SC Targa - since 5/5/2001
Old 11-17-2019, 05:00 PM
Still here
pmax's Avatar
Alternative is to order the equivalent SCAT, SCEET etc aircraft hose. These are flexible and more durable than the paper mache OEM hoses.
Old 11-17-2019, 07:06 PM
