piscator's Avatar
Grinding #4 Intake Runner, O.K.?
Is there any reason I shouldn't grind off the "step" on the #4 intake runner?
I welded a tab to a later aluminum A/C mounting bracket and drilled it to fit my 1979 SC Targa. It's the mount that accommodates a Denso compressor. I think it's called a 'turbo-mount' but I'm not sure.
The mounting bracket fits perfectly, but when I mount the Denso compressor, it bangs up against the "step" on the #4 intake runner. I only need 1/2" more clearance so I won't have to grind into the tube of the intake runner. I can get that 1/2" by re-shaping the 'step.'
Has anyone else done this? Is there any reason not to reshape the 'step?' What's it for anyway?
Lastly, I do have a spare set of intake runners, in case something goes awry.
As always, I appreciate the help!
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Old 10-18-2019, 03:46 PM
Dr J's Avatar
No problem. Have at it.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 10-18-2019, 04:20 PM
piscator's Avatar
Thanks Dr. J!
I was pretty sure there was no reason not to, but it's always good to check. I appreciate your help!
Robert
Old 10-19-2019, 04:05 AM
Still here
pmax's Avatar
Just make sure you don't overgrind it Robert with the BFG !
Old 10-19-2019, 08:02 PM
piscator's Avatar
Top of the Morning To Ye P!
Good advice! All done now and reinstalled. I cut the step off on the band-saw and ground the rest leaving a little extra. The Denso compressor fits beautifully now!
Robert
Old 10-20-2019, 08:17 AM
