Doug
How to upgrade my 69T to Bosch CDI
My 69T did not come with CDI .
Ever since my rebuild with S pistons. Seems to want to foul plugs.
To address the plug fouling .
I would like to upgrade to a CDI system but, am now having second thoughts about using the big MSD (red brick!) .
Just would like to have a more OE look when I lift the deck lid.
Can I retrofit to a Bosch CDI... and if so which Bosch ? 3 pin , 6 pin ?
Thanks in advance for the advice.
Doug
Old 10-30-2019, 04:28 PM
You could use a Streetfire, or the one from the English co, classic retrofit?. But I’m reconsidering ignition. I rode in a dual plug, emotive coils, Clewett pulley triggered hot rod last week. The engine ran smooth and was very fast. I’m thinking I’ll make the jump to coil on plug and ITB injection.
1966 912 to 2.7 Frankencar
Old 10-30-2019, 04:42 PM
HarryD's Avatar
You want a 3 pin unit. You will need that and the correct current transformer (coil). You use your points to trigger the CDI.
This thread my be helpful: forums.pelicanparts.com/porsche-911-technical-forum/1043051-points-condenser-cdi-1973-5-a.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-30-2019, 04:46 PM
HarryD's Avatar
There are other alternatives including MSD.
Harry
2020 MB E350 4Matic
Doug
Harry.
Thanks for the information.
Ton of good info on the thread you recommended.
Just now ...Through another thread I found a recommendation for Bob Ashlock who restores Bosch CDI units.
Regards.
Doug
Old 10-30-2019, 05:20 PM
