-   -   Where to buy cylinder head temp sensors (http://forums.pelicanparts.com/porsche-911-technical-forum/1043068-where-buy-cylinder-head-temp-sensors.html)
gomezoneill 10-20-2019 11:23 AM
I want to replace my temp sensor on my 86 carrera but it seems that the Bosch product is NLA. Only the Porsche brand is available. At 266 dollars.
Any recommendations as where I can purchase this at a better price?
john walker's workshop 10-20-2019 12:09 PM
Ebay has them, sometimes.
86 911 Targa 10-20-2019 12:19 PM
Sensor.
Do a search.
I think the BMW sensors are a bit cheaper.
I would pass on the aftermarket units
such as the URO.
Gerry
Nick Triesch 10-20-2019 01:14 PM
I just had much work done on my 911 and the shop had to order a new one from Germany because none were available in the states. Took 3 weeks to arrive!!!!
Uwon 10-21-2019 03:29 AM
Clewett Engineering.
gomezoneill 10-21-2019 04:29 AM
Sold Out!
trond 10-21-2019 04:47 AM
https://www.aircraftspruce.com/
type K
gomezoneill 10-21-2019 05:06 AM
Originally Posted by trond (Post 10630455)
I don't see any listing could you specify?
db_cooper 10-21-2019 05:31 AM
https://cdn8.pelicanparts.com/catalo...0280130070.jpg
Looks like our host sells the temp sensor.
One is $266 under the Porsche part number 930-606-915-00. The other is listed under the Bosch part number 0-280-130-070 and is $96
Porsche doesn't make the sensor. Bosch does.
https://www.pelicanparts.com/More_Info/0280130070INT.htm?pn=0-280-130-070-INT&bt=Y&fs=0&SVSVSI=810
trond 10-21-2019 05:36 AM
large number of types here;
https://www.aircraftspruce.com/categories/avionics_instruments/av/menus/in/probesandsenders_cht.html
hers is one for 14 mm plug
https://www.aircraftspruce.com/catalog/inpages/falcon14chtsend.php
db_cooper 10-21-2019 06:30 AM
No luck searching Bosch part number 0-280-130-070 ?
spuggy 10-21-2019 08:23 AM
Literally hundreds of sensors that are electrically compatible (eg use Bosch's NTC tech), but the short reach is the limiter - almost everything else has a 17mm projection past the end of the threads.
The 70's VW/914 sensor looks to be the same reach: 0280130012. Replace the spade with a 2-pin EV1/JT male plug, re-cycle your old grommets and good to go.
Seems to be widely available for $20-30, including from your local FLAPS. Reman items are available made from stainless
Yeah, dedicated ground connection would be better. Ho-hum.
john walker's workshop 10-21-2019 08:40 AM
Rock auto lists it under cooling system. GPD1712512. Alt #bc3z7h141a.
proporsche 10-21-2019 08:54 AM
find somebody who has an account with SSF it costs $214..there
Ivan
gomezoneill 10-21-2019 09:37 AM
Sold out of course.
Thanks John
UROParts 10-21-2019 10:25 AM
Our host has 311 906 041A for $17 for anyone wanting to go the VW/914 route: https://www.pelicanparts.com/More_Info/311906041AM253.htm?pn=311-906-041-A-M253&bt=Y&fs=0&SVSVSI=3421
http://forums.pelicanparts.com/uploa...1571682217.jpg
boyt911sc 10-21-2019 10:36 AM
CHT Sensor........
Michael,
I recently bought one from our host. Contact Glenn Sager (PP Parts Specialist) @ ext. #240. Let him know that you want the BMW CHT sensor. It is the same as the Porsche CHT but under a different packaging and part number. And a lot cheaper.
Tony
gomezoneill 10-21-2019 11:00 AM
Originally Posted by boyt911sc (Post 10630912)
Michael,
Tony
Thanks Tony I'll give that a shot. I'm glad I don't necessarily need this. I'm replacing the reference sensors so I thought I'd replace the cht while I was in there. Our host has the Porsche one, since I don't need it I don't want to pay 250 dollars for it.
UROParts 10-21-2019 12:51 PM
Quick FYI: we have sensor 993 606 013 00 in development, but don't have an ETA at this time. Probably looking at another year or so.
spuggy 10-21-2019 01:01 PM
You guys saying "our host has it" need to try adding it to your cart - just because it is listed and doesn't show "NLA" doesn't mean they have stock, but trying to order one will show this.
They didn't have either a few weeks ago when this first came up. They currently don't have the Bosch part, only the $300 Porsche one.
Tony, it'd be really cool if you could post either the BMW or Bosch part # for the CHT - or the model(s) it fits?
