High level scope in a 3.6 L SC conversion:
964 wire harness install and SC wiring integration ECU mounting Complete fuel line conversion; 044 fuel pump to needed 964 accumulator Rear motor mount mod Throttle linkage mod Oil tank breather line mod Flywheel sensor mod |
Pictures please
All other things constant, a good clean SC with a 3.6 is worth more than one with a stock 3.0.:D Other things, like a concourse quality SC to be not considered.. |
My neighbor came over and asked for advice. I gave him all the info from this thread. I just told him to be very careful, Ask many questions. I have a feeling my neighbor will way under bid anyway. I don’t think he has a clue about the value of our cars. But to be fair, he is a long time classic car owner. He has the most perfect, beautiful 1969 corvette I have ever seen. So he can probably take care of himself.
Wonder if there are bigger brakes too, to stop the thing? Wouldn't mind a 3.6 in my SC. I would say the price - point would be at least double than what the average /'numbers matching " SC is selling for.
Here's my Triple Black 3.6L Spec Sheet for Reference. Great Rally and DE ride. If you wanna go get groceries ,go get em!
The car he's looking at should compare favorably to this spec if its built correctly. Engine : 1997 993 3.6 l former varioram engine now with KMS individual throttle bodies,manifold risers and ECU. Split case rebuild 3/2017, with super cup cams /solid rockers,SS valves,Hd springs ,Ti retainers . Heads by Bob Height—Anchor Atlantic NJ. 3.6 L crank pulley and single P.M.S CNC machined fan/hub pulley. Equal length headers/ jet hot coat with M and K 2 / 2 911R stainless exhaust/ w removable baffles.lightweight starter.Custom fabricated rear mount tow hook. Dyno:330 hp 277 lb/ft tq.@5800 rpm Transmission :915 -rebuilt 3/2015 w Quaife torque sensing differential new synchros / shortened 3rd,4th and 5th gears. Saks Al Power Clutch and Patrick Motorsports 993 conversion kit to 915 gearbox, including 225 mm fly wheel New motor mounts and trans mounts were installed at same time as trans rebuild- Wevo : tall/black anodized shifter/ coupler/shift rod/tube. Interior: Black dash and Black headliner/sunroof are in perfect shape. RS America door panels, Kirkey series 45 lightweight aluminum seats and mounts .OMP Black suede/leather 360 mm steering wheel. Diest 5 Pt harnesses .Das sport-black satin powder coat bolt in Roll barr. Interior fuel pump switch and hand throttle/choke. White face gauges rebuilt by Hollywood speedo. Recalibrated to 200 mph. shift light set @6800. Rennline - aluminum track mats/dead pedal. Interior mounted KMS(Koenigsberg) ECU and relay panel behind drivers seat . Exterior: Carrera repro rear spoiler with OEM rubber lip. IROC fiberglass front valance with fabbed cooling ports in valance and bumper for dual carrera oil coolers (right and left sides) Front valance is mounted to a stock aluminum front bumper via lightweight solid tubes. New sunroof seal and windshield 3/2015. Rennline front tow hook /fabbed rear tow hook – engine carrier mount.Summit racing tie downs front(a arms) and rear(shock mounts) Two sets of rims :A)17 “Fisk FM 5 ‘s 7”/ 9 “ w BFG R1’s B)Carrera Cups- repros 17 inch 7”/9 “inch w Toyo R888’s.Ventilated/ lightened rear aluminum bumper on solid / lightweight-bumper shocks. Chassis and suspension: RSR Bilstein re-valved shocks -front and rear. RSR lowered spindles – front . New steering rack ,New axles and CV joints-3/14.Stable energies triangulated strut brace New trailing arm bushings, front control arm bushing’s and rear spring plate bushings replaced 4/15 .Smart racing products rear sway bar @ 4.0 stiffness . Smart racing products through the tub front sway bar @ xx stiffness.- new rear sway bar bushings 5/19. Corner balanced. -3° street/track camber.. Rennline battery mount with new lightweight Decca AGM battery. Brakes: Rebel Racing Brembo Big Red Kit- drilled/vented/fixed rotor disks : front rotors 322 X 28 MM - drilled / vented rear rotors 309 X 28 MM - drilled / vented Brake pads: Porterfield RS 4– street Pagid yellow – track As others have said,It is a wickedly fast,visceral ride |
So here is the end of the story, My neighbor went to look at the SC with the 3.6 conversion, made an offer and was rejected. His offer was way too low. My neighbor did not do any homework and he did not understand P cars. If he needs to know about another 911 in the future I will politely tell him to go to our nearest Porsche expert for a PPI.
