Trickle Charge over Winter
Hi - is it advised to keep a trickle charge on the battery in the winter? May drive a little, but car will definitely be sitting a lot from December - March/April.
Thank you,
Greg
Old 10-22-2019, 06:41 AM
Stutzdriver's Avatar
Get a proper battery maintainer, not a true trickle charger. I love it that my car is ready to go anytime! I hard wired mine in so it just has to be plugged in easily.
Jay Traner
1984 911 targa
1923 STuTZ 690 Touring
2014 VW CC 2.0T
2021 Subaru Forester (Mrs)
Old 10-22-2019, 06:45 AM
Thank you Jay! Appreciate the fast response.
Old 10-22-2019, 06:51 AM
El Duderino
tirwin's Avatar
I have one that is a Battery Minder brand. It's probably 10-15 years old at this point but works great. It has settings for 2, 4 & 8 Amp charging. It also has different setting for regular lead/acid and AGM and a third one I can't recall right now because I never use it.
On the battery side I wired in a quick charging port and a temp probe (safety thing - prevents battery from over-heating).
I'm sure there are other brands out there.
One thing I would look for is one that can desulfate the battery like the Battery Minder.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 10-22-2019, 07:01 AM
Thanks Tim! Great details. I think 2A is correct for maintaining??
Old 10-22-2019, 07:14 AM
El Duderino
tirwin's Avatar
2A is fine. Higher amperage is good for resurrecting a dead battery or when time is of the essence.
Old 10-22-2019, 07:43 AM
kent olsen's Avatar
Curious. I have three cars I leave alone over the winter. Basically Dec thru around the first of April. All I've ever done is disconnect the batteries and set the cars on jack stands. When I come home I hook up the batteries set my charger for 2 amps overnight and they are good the go the next morning.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 10-22-2019, 10:24 AM
Bill Douglas's Avatar
I use one of these.
Old 10-22-2019, 06:53 PM
Troll Hunter
This is a good plan. Batteries do fine when not connected.
FYI for my water cooled friends. Make sure you leave your hood popped open when storing the car. Once your battery dies and your hood is closed, it's a bit of a project to open it back up....just saying.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 10-22-2019, 07:25 PM
I hooked my battery maintainer up to a 120volt timer. Set it to charge 6-8 hrs a day, that way it wont burn up my battery.
Old 10-22-2019, 08:23 PM
Wildman Emeritus
The last several years I trickle 2A about once a month for several hours. I do disconnect the battery so the clock is not draining it during winter storage.
Never had a problem with charge or battery life. I think that perhaps the new batteries are more resilient than they were years ago when they seemed to die if not kept charged. Same technology but....
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-23-2019, 06:25 AM
El Duderino
tirwin's Avatar
Obviously nothing wrong with this approach. That works for you, but not for me.
I never put up a car for the winter because of where I live. But I travel quite a bit for work so I may go several weeks without starting the car when I'm not home. When I get home from a drive, I connect the charger. It literally takes 30 sec. And when I go to get in the car the next time I don't have to reset the clock or all the radio settings that get lost. I just disconnect it, get in and drive. Plus the charger I use has a setting for the AGM battery I use. When it goes into float mode, it pulses the charge to prevent sulfation, which improves the battery life (or prevents premature failure -- I guess it depends on how you look at it).
Old 10-23-2019, 07:19 AM
El Duderino
tirwin's Avatar
The difference that I'm aware of is traditional wet lead-acid batteries are usually toast if they get completely discharged whereas an AGM can usually be resurrected from the dead.
Some references I've found say that traditional wet lead-acid batteries can only handle 50% depth of discharge and AGM can handle 80%.
Old 10-23-2019, 07:29 AM
kent olsen's Avatar
Well my youngest car is 26 years old and the oldest of the 3 is 54 so no modern conveniences. Their all manual from the transmission to the door locks.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 10-23-2019, 09:43 AM
Tags
trickle charge
