Today was a very exciting day for me!
Today I registered my 75 for the first time in over 8 years, and got to drive it!
I only went 60 miles as I am still trying to build up a trusting relationship with her again.
8 years ago I took a job as a traveling tech working on those big wind turbines and my car didn't get much attention. I started a thread here when I ran into some problems and decided I was going to start fixing everything. Turns out, I opened a big can of worms where nothing on this car was done right by previous owners.
Long story short, I only had maybe a couple weeks a year where I could do anything to it so it took me much longer than it should.
I also had this weird oscillating air sensor plate that turned out to be the FD. (There is a metal piece inside where the plunger goes that got pushed up somehow and partially blocked the port to WUR.)
Now that I can drive it, I need to look into what looks like low oil pressure. It was reading a tad over 20 psi at around 3400 rpms. Oil temp was around 210F (almost 100F outside today.)
Chris
'75 911s Targa
Old 08-27-2018, 06:19 PM
Functionista
manbridge 74's Avatar
That is low but don’t panic because maybe the sending unit isn’t up to par after all the years. I’d confirm with a mechanical gauge first. Does the light stay on solid at idle?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-27-2018, 06:54 PM
Bill Douglas's Avatar
What a joy. And remember the more you drive it the more reliable it is.
Old 08-27-2018, 07:01 PM
Didn't notice the light. I will check it out tomorrow. How does one confirm with a mechanical gauge?
That's what I am hoping for.
Chris
'75 911s Targa
Old 08-27-2018, 07:24 PM
Bucketlist's Avatar
Good to see another Aircooled guy in the 'hood.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 08-28-2018, 05:31 AM
Flojo's Avatar
Cheers! Enjoy!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 08-28-2018, 06:17 AM
billh1963's Avatar
You just pull the sender and screw in the appropriate size hose with a mechanical gauge. Do a quick search on pelican..... people have posted the correct fitting info in the past.
If it were me I would just replace the sender. If you didn't have a problem with oil pressure before then your sender is going bad (mine did the same thing), It's a very quick and relatively inexpensive fix.
Old 08-28-2018, 06:23 AM
Cool I am down in Lubbock all the time since there isn't ***** in Plainview. Maybe we can meet up sometime when I am not working
Yeah probably not a bad idea. I might just do that.
Thanks all!
Chris
'75 911s Targa
Old 08-28-2018, 07:21 AM
SalParadise's Avatar
Right on.
Old 08-28-2018, 08:45 AM
Senior Member
Superman's Avatar
I'd guess it is more likely the sender has failed than the oil pressure itself. If not the sender, then perhaps something else simple. Pressure relief spring maybe? The oil pump, pressure galleys, main and rod bearings, etc., are pretty reliable by design.
Mocha 1978 911SC. "Coco"
Old 08-28-2018, 09:02 AM
Took it for another drive today. At start up and when the oil is cold the oil pressure seems good. When it gets hotter I can watch the pressure go down while cruising at highway speeds. I did order a new sender this morning before the drive. Do you still think that could be it? I am going to get a mechanical gauge to verify but I guess I can only check while at idle.
On another note, I did notice a very slight surge at idle and fuel consumption seemed high for the short time I have been driving it. RPM's dipped when I pushed in the clutch as well. All signs of running rich. I used my gunson to check CO and it was way high. Brought it down to around the 3.0-3.2% range. No more dip in rpm's and no more surge.
Chris
'75 911s Targa
Old 08-28-2018, 03:30 PM
Functionista
Post a pic of your sump plate where the drain plug is. If the drain plug is in the wrong position due to sump plate installed wrong you can have cavitation and the foamy oil will not be conducive to good oil pressure.
Jeff
74 911, #3
Old 08-28-2018, 06:27 PM
When I had the engine out of the car and on a stand I had this plate off. I made sure when I put it on it was oriented in the right position but it doesn't hurt to double check my work.
Chris
'75 911s Targa
Old 08-28-2018, 07:10 PM
Eva
911SauCy's Avatar
These cars do require love, but once understood, it's these simple fixes that are soo satisfying.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 08-29-2018, 04:54 AM
Bucketlist's Avatar
[QUOTE=allaircooled;10159666]Cool I am down in Lubbock all the time since there isn't ***** in Plainview. Maybe we can meet up sometime when I am not working
Cars & Coffee 1st Saturday of the month 8-10am Cooks Garage, Lubbock
Be there this Saturday, See Ya!
Old 08-29-2018, 05:10 AM
At those temperatures make sure you are using a 20-50 oil
Old 08-29-2018, 09:41 PM
Well darn it, I just drove to Florida to visit my son. Maybe I can make it to next months! Was wondering what the deal was with all those signs at that place.
I am using 20-50 brad penn. All though it has been in the engine for around 2 years now. Engine ran with this oil a little over a hundred miles and maybe 2-3 hours of idle running time while I was trouble shooting and adjusting. Wondering now if I should just go ahead and change it.
Chris
'75 911s Targa
Old 08-30-2018, 08:05 PM
I don't seen any downside. I think an annual oil change regardless of mileage may be a bit overkill with today's modern/synthetic oils but it's always been my practice in any vehicle. Pretty inexpensive in the grand scheme of things.
Must feel amazing to have it back on the road. I know how excited I get after just a couple weeks or months.
_______________________________
1982 911 SC 240,000mi and counting
Old 08-31-2018, 10:07 AM
Isn't that an awesome feeling? I am just building a relationship with my '68 again after she was a driveway queen for several years, and I'm overjoyed too. Congrats on getting yours back on the road.
Old 08-31-2018, 11:46 AM
Yeah it is a really good feeling for sure. Still have plenty of work to do but at least now I get to drive it.
Chris
'75 911s Targa
Old 08-31-2018, 09:07 PM
