-   -   Splitting Calipers (http://forums.pelicanparts.com/porsche-911-technical-forum/104352-splitting-calipers.html)
rob justice 03-30-2003 12:11 AM
The on going restoration continues!!!
I am now at the point of rebuilding the brake calipers and after speaking to my local Porsche Dealer - the o-seal and between the two caliper halves and the fasteners used to bolt the two caliper halves together are not available or listed by Porsche - basically I don't think they want you to split the calipers.
Has anyone got any ideas where I can obtain the parts required?
The car is an 85 3.2 Carrera.
Best Regards.
Rob Justice
emcon5 03-30-2003 12:33 AM
Why do you want to split the calipers, are they leaking?
Most folks don't in a rebuild. Just the seals in the pistons, and the dust boot thing.
Tom
mike95125 03-30-2003 12:35 AM
Pelican has em for about a buck each.
Early_S_Man 03-30-2003 12:35 AM
Rob,
Unless the calipers are leaking at the parting line ... there isn't any reason to split the halves. Are they leaking there?
rob justice 03-30-2003 02:19 AM
Plan was to get the calipers either acid dipped or bead blasted to remove all corrosion then get them powder coated or plated to original finish.
I thought any of the above would either fry or melt to internal o-seal.
Glasgow 911SC 03-30-2003 04:19 AM
Rob
Look at this thread for info about the seal.
I've got a set of front calipers that I plan to rebuild and powdercoat (I'll get around to it eventually!). I've been pondering whether to split them or not but I think I'm just going to go for the powdercoat. Otherwise it would be a case of powdercoating the parts of the caliper seperately and then rebuilding them. I'm sure I would end up ruining the finish going this route!:rolleyes:
The guy in this tech article powdercoated his calipers without even removing the pistons.:eek:
rob justice 03-30-2003 04:30 AM
Superb - just the bolts to find now!
rob justice 03-30-2003 07:02 AM
Glasgow 911SC - I had my wheels and suspension parts powdercoated - the finish appears very tough - I think a simular coating on the calipers would be very long lasting. The problem now is the calipers look crap along side all the shiny parts!!!!
