Harpo's Avatar
Fuel line grommets
Good afternoon everyone & happy 4th of July
I have just removed my old fuel lines and plan on installing my new lines this holiday weekend. To remove the old lines I ended up destroying two of the grommets that go in to the body. Because I have two diameters of fuel line I need two different size (ID & OD). I found this one but according to the PET there is only one size.
Old 07-04-2019, 11:44 AM
Harpo's Avatar
The large grommet: OD = 20mm - ID = 12.5mm
The small grommet: OD = 16mm - ID = 8.3mm
The I'd of the small grommet best fits my new aluminum fuel linesl
Old 07-04-2019, 11:52 AM
Harpo's Avatar
The holes in the body are approx. 17mm & 13.5mm
Old 07-04-2019, 12:01 PM
BoxsterGT's Avatar
Porsche Crest
Looks like you have a 74 with those damned white (now brown) Nylon Tunnel lines.
Good move to replace them.
The grommet replacements you show are for the later models S, SC and Carrera.
You need the Grommets that were for the small dia line on the 914 model, w P/N 914.356.201.00.....
I have these in stock. Also, in case you need them I have Compression rings to fit your Aluminum tube with standard M14 Fuel Fittings as well as for AN-6 or AN -8.
Hope this helps. Good luck.
Got to keep these wonderful cars on the road for generations to come.
Len.Cummings at verizon.net
Old 07-04-2019, 12:23 PM
Harpo's Avatar
Thanks Len, I just ordered 4 of those from our host. However i currently have two different sized grommets. I suppose I could silicon the smaller of tubing in the larger grommet
Old 07-04-2019, 02:22 PM
BoxsterGT's Avatar
Porsche Crest
Just a FYI in case someone else is thinking about this method w Aluminum tube.....
I use this for chassis hardline repairs on 911s and 944s as well as for other Metric applications.
Len
Old 07-12-2019, 05:09 AM
BoxsterGT's Avatar
Porsche Crest
Bump!
There are still a few 74 911 owners out there who do not know about the failure rate (frequency) of their original White Nylon Tunnel Lines shown above.
You MUST replace them, as your 911 is running a very certain risk of FIRE if the original lines crack or crumble when disturbed.
Beware.
Old 11-01-2019, 05:13 AM
