Harpo's Avatar
Cleaned up my oil tank
My tank was looking rough so I steam cleaned the inside and powder coated the exterior. I have purchased a new gasket and oil lever sender. How do I glue the gasket to the tank?
Old 10-20-2019, 09:54 AM
Harpo's Avatar
Old 10-20-2019, 09:59 AM
Tom '74 911's Avatar
Pretty sure there is no need to glue it. Doesn't it get squished between the tank and fender well when you bolt the tank back in? Maybe I am misremembering, but I don't think I've ever glued one of those seals on...
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 10-20-2019, 10:07 AM
Harpo's Avatar
Yes, it definitely will get squished once it is installed. When I removed the old one is was stuck in place so I assumed that it was glued in place.
Old 10-20-2019, 10:12 AM
Double make sure the inside of that tank is VERY clean the oil is not filtered from the tank to the engine
Old 10-20-2019, 01:28 PM
I glued mine with a simple contact adhesive (Evostick) figuring that once it is clamped in place the glue has done its job so it wouldn’t matter if it couldn’t take the heat. The biggest challenge was trying to compress the seal as I attempted to fit the nuts to the studs. Not easy!
Old 10-20-2019, 01:40 PM
Harpo's Avatar
To ensure that the tank is clean I plugged the holes again and put a gallon of mineral spirits swishing it around every hour. After eight hours I drained the very dirty mineral spirits. I refilled it with a gallon of clean mineral spirits and will let it soak over night. I guess I will continue with this regimine until the mineral spirits comes out clean. I don't want to take any chances.
Amazon is supposed to deliver a bore scope tomorrow so I can see inside.
Old 10-26-2019, 04:36 PM
Functionista
manbridge 74's Avatar
These cork gaskets can become porous after some time and begin to seep. I believe the factory used something like Loctite 574 to rub into it to avoid seeps. Not a lot, just a little.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-26-2019, 07:07 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Kero would work too. Might have a little more bite than mineral spirits.
Drain the solvent through a towel into a bucket then you can re-use it.
1981 911SC Targa
Old 10-27-2019, 09:19 AM
Almost Banned Once
sc_rufctr's Avatar
This is what I did when I restored mine almost 15 years ago. No issues.
- Peter
Old 10-27-2019, 09:29 AM
