lightest SC weight WHILE preserving front weight?
There are a lot of threads on attaining the absolute lightest weight in 911s. However, it has always occurred to me that to potentially improve the F/R weight distribution while lightening, and I often try to lighten my cars, I usually focus that effort on items located in the rear and high up.
So I wonder whether selectively keeping some relatively "heavy" items in the front seriously impedes total weight loss. I think the answer is no, but would love to hear the experiences of others. In my current SC targa project (in which I am mainly grappling with EFI issues per another thread - but I'm taking parts off as I ponder that), I am also working towards this front weight-preserving weight loss strategy. My approach includes: Removing the whale tail decklid - will replace with either a ducktail or a simple FG/CF lid Removing the entire A/C system Converting to a soft window targa kit Removing rear seats Using TRE 911R taillights Using a FG rear bumper Perhaps using a FG or CF targa top skin with a fabricated aluminum frame - doubtful ROI there, though... Lighter exhaust I speculate that all of that should result in >150 lb. weight loss that is substantially focused on the rear of the car. Will weigh items as they come off. |
Removing weight from the rear of a 911 does make sense as you say. I’m not sure if you’ll get as much value as you might think by expressly avoiding removal of weight from the front. While I get the theory, I’ve never heard of someone removing too much weight from the front and ending up with a poor handling 911.
How much weight does the R type rear lights really save? It would be interesting to see a list of parts and weight saved. What about aluminium trailing arms versus stock on my '71? Too much effort for too little gain?
I would think, a lighter front windshield, and Lexan side and rear windows would offer a good level of weight for cost! |
there are several lists of parts and weight saved... you'll have to search for them
the tail lights are quite heavy, moreover you'd be saving wt. at the extreme end of the car which is important as you need to consider momentum for handling Al trailing arms are lighter and also stiffer - well worth it |
I think you're on the right track and make a good observation. I got my car down to about 2300 lbs ("street" car with a roll bar and I wasn't doing anything drastic) but in order to do this I had to remove the spare tire. That resulted in a little bit more rear-bias to the CG than I thought was necessary, though, so I usually ran it with the spare tire in.
Tail and rear bumper weigh a lot compared to fiberglass and obviously they are pretty far from the CG, so they are low-hanging fruit. My rear bumper weighs 7 lbs and I think my whole factory setup was close to 30. |
But, front end lift has historically been an issue in early 911s at speed. Removing substantial mass in the front is probably not the best approach if you are going to ever track the car or see serious speed on the road. The weight distribution will surely remain heavily rear-biased despite all of these efforts. |
To improve the dynamic behavior of a 911 all weight loss is good, removing it from the front is as important and effective as at the back because the polar moment(which is a major determinant of dynamic behavior) depends on the mass and the length of the lever arm from that particular mass and the CoM. The lever arm from CoM to the front is longer than the lever arm from CoM to the rear, meaning a kg lost at the front bumper has a larger effect than a kg lost at the rear bumper. Correspondingly weight lost from the roof has the least effect because it's moment arm is so short and weight lost from the seats is almost the least effective. Taking honors for least important is the transmission case which is right at the CoM.
There is nothing inherently bad about a 40/60 wt distribution compared to a 45/55, You just drive the car a little differently, w/ these cars the throttle and brakes are more important than weight distribution, gas is glue for the rear and the brake pedal is glue for the front end as long as the tires grip isn't exceeded and these days it's easier to over-tire a 911 than to under-tire one |
Have at it...you can always add a bit back up front if you have an issue but I doubt you will...I am down to 2300 lbs fully wet with an '83 SC coupe....I did lose the sunroof/bumpers/AC and a great deal more but it is a street car that occasionally see's 120ish....never noted any poor handling or lift.
I do have a glass Duck and SCRS bumper that is less of a front air dam that the stock SC....I don't note any difference tho. |
I have a 930 front lip on the car, and will keep that and the stock front bumper. My feeling was that this would be a good combo with a ducktail for the occasional DE event. Maybe the simple decklid (while light) will not be the best way to go.
You could lose the fan blower motor and swap in SSIs and Dansk for q bit of weight loss from BEHIND the back wheels.
the guy who did the documented wt. loss on a bumper car was screen name <something> Joe maybe ShakinJoe, IIRC
he used a scale/balance for HVAC work so pretty accurate wts. |
I’ve gotten my car drastically light and still very streetable (2080# fully wet). Here is what I’ve learned about my car. When I have a full tank (custom 25 gallon ) through 1/2 tank the car drives great at all speeds. I’ve had it up to 130 no handling problems. But once it starts to get light on fuel I can feel the front end lift and it is more of a handful above 90. I’m going to install a front splitter and see if I can add more downforce on the front. It has a 964 spoiler but I can’t tell the difference when it’s up or down so there’s definitely plenty of weight in the back.
Feeling that light front end sensation when cornering is thrilling - fighting the natural urge to lift the throttle...still, improving F/R distribution while lightening seems, at worst, harmless, and most likely, beneficial if aero has already been addressed. |
At speed aero is more significant than weight, the faster you go the more so
here are the drag and lift curves for a '73 w/ & w/o '73RS aero http://forums.pelicanparts.com/uploa...1572359136.jpg and here is for the'74 up http://forums.pelicanparts.com/uploa...1572359136.jpg 964 http://forums.pelicanparts.com/uploa...1572359248.jpg 964RS http://forums.pelicanparts.com/uploa...1572359248.jpg 993RS http://forums.pelicanparts.com/uploa...1572359248.jpg 993RS/CS http://forums.pelicanparts.com/uploa...1572359278.jpg |
Cool material. Reminds me of the old C&D article reviewing the 74 911 that was dredged up recently:
http://forums.pelicanparts.com/uploa...1572368789.jpg |
I am addicted to reading Bill's post. He really has the data. Awesome.
My SC, no wing, front chin spoiler, slightly low stance, feels decidedly firm and stable at speed. I've taken curves at 100mph and it felt fine, and have done 135mph on the straights - felt great.
I probably get less turbulent air going under the car than the average 911. |
The problem area for 911s is more at the rear due to the shape of the car and slope of the rear top surface these contribute to instability at speed particularly in a cross wind
On the original B series cars wind tunnel testing @ 230kph showed front lift at 815N rear lift @1113n what is rarely discussed is the effect of a cross wind on these #s, w/ a 22.5° yaw angle lift in front rose to equal that in back , at angles > 22.5° front lift was larger. This puts the center of pressure way out in front ~80cm ahead of the wheel base center. The net effect is that though the forces are equal the action or effect is still 85% on the rear. The early factory effort to quell this by placing 11 to 22kg of lead in the front bumper corners was a help but not a cure, later efforts to move weight forward also helped but didn't cure the issue. The real cure was from longer wheel base, aero aids particularly in front that matched weight and lift staggered wheel and tire fitments |
you can keep the stock look of the rear lights with plastic reproduction light buckets. Keeps the stock lenses, but obviously the buckets are much lighter. The stock buckets are heavy. They solve a lot of reliability with lighting in these 40 year old buckets as well.
I'm really interested in the last paragraph of the article section I posted above. 200 lbs of front lift with or without the duck at only 60 mph! And 60 more lbs with the duck at 120 mph...if I read it right. I have been able to lift the front end of some of my 911s off the ground by hand - it makes me wonder how much effective weight is left on the front wheels in an early car if going >100 mph with no front lip or ducktail.
A ducktail and front lip really need to be done together. This was the setup I had on my old 911E, and it handled quite well, albeit still feeling a little light in front at times. |
So what is the best way to add more downforce on the front. Splitter? Or is it more involved than that. Would some type of rear defuser also help. I know we’re getting into aero know and it’s not what the original poster was asking for but I think it would be helpful.
The best thing is a lowered car, ~2 - 5° rake, as deep and projecting an air dam as possible(for street it'll be less so), do use a rear spoiler, effectiveness in increasing order duck, flat whaletail, wing, wing w/ end plates high wide wing w/ end plates, the yaw effects are much reduced w/ flatter fenders aka Flachnose or 993 |
I wonder if Aircraft Windshield co. In Anaheim makes poly rear targa glass? That would save some major weight. Their race glass is really high quality too.
So my backdated '78 Targa (now sold) weighs 2000lb wet.
To answer some of your questions: Rear tail lights weigh about 5 punds each. Carbon fiber, including Hella lights as pictured below is about 0.7 punds. Thats about 8 punds off the rear end. The Targa rear window can be exchanged for a polycarbonate one. You dont need to have one made, it can be cold-bend to fit with a few bolts. It shaves 14 punds of compared to original window. You can see both the polycarbonate window and the rear taillights here: http://forums.pelicanparts.com/uploa...1572442539.JPG I found, that without any front spoiler, the car feels very nervous at speeds > 80 mph. After fitting an SC spoiler (no rear spoiler) - the car was transformed and felt plantet even at +120mhp. You can see it fitted here: http://forums.pelicanparts.com/uploa...1572442539.JPG To get a Targa to 2000lb you need to be pretty radical. Minimal interior. Fiberglass everything - incl doors and seats. Polycarbonate windows - or no windows at all. Headers w/o heat and fx a M&K exhaust remove A LOT of rear weight (+30lb. As does EFI/ITB's (about 20lb). The original rear bumper alone is about 34lb. Front spare tire is 20lb. LiFePO4 battery saves about 22lb. But thats at the front. If I were to build another light weight 911, I would not use fiberglass doors and keep the original Targa rear window. Less radical seats. |
1988 3.2 Carrera, just as a point of reference:
M&K muffler and cat delete 16 Rear bumperettes 14 A/C 54 Rear seats and sound proofing 38 Odyssey battery 14 Spare tire 33 Total is around 170 lbs Presently with radio delete, cruise, fog light delete, front and rear hood and frunk struts and lots of little stuff, the car has lost a total of around 210 lbs. Spreadsheet shows about 87 lbs removed from front of car and 120 lbs rear. Car handles great. |
http://forums.pelicanparts.com/uploa...1572542024.jpg
My 72 weighs 2210 with half a tank. I have not had the spare tire in it in 20 years. Corner balanced at about 40/60 and a 245hp 3.0L. 15 x 7 superlite wheels at about 1 lb more than Fuschs and Yoko Advan tires. I have tracked the car many times and to me the handling is near neutral and the only limiting issue is the 205x50 tires. Coming home from the coast monday on a great mountain road I could comfortably take posted corners 20-30mph above that speed. |
https://www.*****************/fu/prod13509/Indicator-Lamps-and-Lens-Rear-Kit-with-BLACK-Rim-Lens-Porsche-911/ ok, clearly not, it is design 911 in england...but there are others out there. |
Great looking car - can't believe you got rid of it! |
Thanks wreckah
Don't forget seats and doors. There is a lot of weight to be saved there.
Listen to Bill. He speaketh the truth. Front end lift? http://forums.pelicanparts.com/uploa...1574126442.jpg |
Glasfibre hood, bumpers, seats (Recaro), no jack, tools, spare, rear seats, roll bar could go to save weight, the jury is out on that.......
http://forums.pelicanparts.com/uploa...1574127538.jpg |
I'm at 2233 lbs with 1/4 tank of gas. Though I'm not an SC, the mods are applicable, and I'm running the stock bumpers.
Front: regular battery, no Jack, spare, air pump. No AC. No washer reservoir, pump or tubes. Euro crush tubes. - running a front spoiler. Rear: Plastic tail light housings, euro crush tubes, rubber delete from bumper, heat back date, no smog pump or AC. Lightweight muffler *17lbs Interior and middle: rear sound pad swap to lightweight appbiz version. Rear seat delete and sound pad delete, floor tar/sound deadening removal, RS carpet, RSA door panels, no stereo/audio equip, sunroof delete, rocker panel delete, no wheel caps, single side view mirror. Also I lost 36lbs on my person. :-D 15" wheels, 6 and 7, titanium lugs. Car handles extremely well. It's very low and I run the duck tail and previously mentioned front spoiler. Only issue I've had is cold tires and lifting on sharp corners. That's all driver error though. http://forums.pelicanparts.com/uploa...1574170992.jpg |
| All times are GMT -8. The time now is 10:36 PM. |
