-   -   Fuse question (http://forums.pelicanparts.com/porsche-911-technical-forum/1043857-fuse-question.html)
Ruxin 10-29-2019 04:27 PM
Fuse question
I have a 1988 3.2 Carerra and am having a new problem with a blown fuse. The fuse in spot #4 which controls the clock, radio and interior lights continues to blow. I have replaced it now 3 times and each time the battery gives a small spark and the fuse immediately blows. I am using the recommended 5A fuse (European) that the panel recommends. This is new problem and began a couple weeks ago. Any ideas? Ways to test and repair? Thanks, in advance.
Ruxin
86 911 Targa 10-29-2019 04:46 PM
Fuse.
I would lift the bottom wires on the fuse one at a time to fault isolate.
pm me as needed.
Gerry
Artfrombama 10-29-2019 08:21 PM
My 1973 did the same thing/same fuse. Traced it to the passenger side interior dome light shorted. Your results may vary.
timmy2 10-29-2019 08:52 PM
Glove box light circuit melts a lot of dash harnesses.
