Wide Band O2 sensor or Tec3r
I am a Tec3r novice, but I need to figure out how to install a wide band O2 sensor into my 3.2 SS from a 3.0. Any advice would be appreciated.
If this is a dumb question, expect more. I just spent a morning swapping my fuel pump because my relay was bumped out. This is from this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/1038716-3-2-short-stroke-flat-spot-4k-tec3r.html |
The ECU will take any O2 sensor through a controller which could be pretty anything (there are plenty brands to consider) so...
manual of how to hook it up is here http://electromotive.com/wp-content/uploads/2015/05/TEC3r-Manual-1.10.H.pdf |
Thanks for the reply, the electromotive guide basically says to install WBO2 sensor then describes how to get the TEC3r to start using it. I guess I need a bit of remedial help on how, and where to install it.
| All times are GMT -8. The time now is 02:41 AM. |
