Early 911 Upper Steering Bushing
All:
Looking for the upper steering bushing repair part for early cars. It's NLA from Pelican. Anyone have an idea on where to source, or might have an extra? Thanks!
Old 10-26-2019, 04:34 PM
You sure? I bought a bearing and a shim to take the play out. There is a thread about removing steering play. Some guy made shims to fix it. Use DDG to search with siteelicanparts.com
1966 912 to 2.7 Frankencar
Old 10-26-2019, 07:52 PM
Harpo's Avatar
I could not find it either on our host web site but I did find it on rennline
Old 10-27-2019, 04:21 AM
proporsche's Avatar
the early had spring and some spacers if i am not mistaken??
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-27-2019, 06:33 AM
FCP Euro or Parts geek has the upper steering column shim for 14.00. I changed mine with ease. Slides right on.
Old 10-27-2019, 08:03 AM
Old 10-28-2019, 12:23 PM
https://www.pelicanparts.com/catalog/shopcart/PERF/POR_PERF_RENN22_pg53.htm
Cheers,
Harry.
Old 10-31-2019, 11:05 PM
HarryD's Avatar
Originally Posted by Harry998R View Post
Hi Harry!
Sorry but that unit is for the 1974+ columns. This is the correct solution.
Originally Posted by HarryD View Post
Your car does not use the bushing repair.
Our fix is different. You will need the spring and bushing that was there from the factory.
Check this thread:
HELP! Steering wheel bushing quickfix???
Mitch Leland Made an aftermarket version of the NLA bushing:
1969-1973 split ring steering bushing
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-01-2019, 10:01 AM
AutoBahned
RWebb's Avatar
You do need the spring and bushing that was there from the factory as per above, but...
you may also need the actual needle* bearing - I had to buy a used one from PartsHeaven for my '73. They are NLA.
Beware of doing what a PO did to my car: he hammered in a non-stock bearing that almost fit, but it greatly restricted what steering wheels could be used, and I had a devil of a time getting it out of there...
* talk about overkill....
Old 11-01-2019, 12:24 PM
proporsche's Avatar
gus..i think i have somewhere the spring and the ring...if you are not able to find it i can donate it to you -1st i have to find it( i do have it thou, for past 25 years) let me know
Ivan
Old 11-01-2019, 04:45 PM
HarryD's Avatar
I am thinking that this bushing should be the same on the early 911's. Per my 64-69 PET, the Part number is : 695-347-725-00.
Check this page in the Pelican Catalog: https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?description=69534772500&make=POR&FILTER_SVSVSI_5878=ON&Category_PartNumbers=ON&Category_TechArticles=ON&description_side=69534772500&GoSearchSideFlag=&command=DWsearch
Looking at the web page for the Porsche parts place in Ohio (S T O D D A R D), they show this part as being for a 356 but sure looks the same. Perhaps a call to them (440-869-9890) can verify if this is the correct part for your car.
Harry
2020 MB E350 4Matic
Old 11-01-2019, 05:39 PM
(man/dude)
Jonny042's Avatar
Yup. Sorry for the upside down pics. If you need the needle bearing it is still available but last I checked was over $200.00
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-02-2019, 10:24 AM
HarryD's Avatar
Thanks for the verification.
Harry
2020 MB E350 4Matic
Old 11-02-2019, 11:16 AM
AutoBahned
RWebb's Avatar
$200 !!! well, it's nice that they brought it back...
Old 11-02-2019, 02:19 PM
HarryD's Avatar
Not sure what you are looking at.
The part I have the above link to is $25 for the repro or $35 for the Porsche part.
Harry
2020 MB E350 4Matic
Old 11-02-2019, 07:16 PM
E Sully's Avatar
The price on the original upper shaft bearing for 1973 and earlier, 914-347-711-00, is currently listed for $271. https://www.pelicanparts.com/catalog/SuperCat/5878/POR_5878_SUSSTR_pg5.htm#item19
The Mitch Leland split ring bushing was for early cars 1973 and prior. It looks similar to the one Harry D shows, but I don't know if the dimensions are the same. It took up the slack caused by wear in the early 914-347-711-00 bearing and steering shaft without having to replace the bearing.
Ed
1973.5 T
Old 11-03-2019, 07:59 AM
