-   -   Quick query for you trans guys out there - is throttle pivot shaft removable?? (http://forums.pelicanparts.com/porsche-911-technical-forum/1044181-quick-query-you-trans-guys-out-there-throttle-pivot-shaft-removable.html)
chrismorse 11-02-2019 03:46 PM
Seriously, is that little throttle pivot shaft on the left side of a 74 mag case tranny removable?
If it is not threaded in, I will just leave it in place.
The shipping crate I built is tight and if it were out, it would give a bit more wiggle room.
UGLY crate, but stout - soon to be off to CMS for overhaul/upgrades.
Thanks,
chris
john walker's workshop 11-02-2019 03:49 PM
8mm open wrench on the end.
jpnovak 11-02-2019 03:50 PM
Yes. It unscrews from the case. Put a dowel in the cotter pin hole and unscrew.
Harpo 11-02-2019 03:55 PM
YES, mine was hard to remove so I put a torch on the boss on the trans and eventually it came out.
chrismorse 11-03-2019 06:01 AM
Thanks guys, I'll try the wrench and heat.
chris
