Analog Air Cooled
Where do I plug the power seat plug into dash side?? w pics
Fiddling around behind dash, and this was loose. Noticed my seats power ( 4 pin ) is off line. After fiddling. Parts manual looks like this is the seat hook up.
Does ANYONE know where this little thing hooks into? Or is it something totally different and I have another issue. ![]() ![]()
Pretty sure that connector is for Autoheat (climate control). In my '87 I have that connector free (unconnected), as I do not have Autoheat, and my power seats work just fine.
Spray some De-ox or equivalent deoxidizer into the power seat switch (assuming there is a proper connection under the seat) and exercise the switch a few times. That may get things working again. Otherwise you will need to trace the seat wires back to find the fault (check fuses too, of course). Good luck.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Analog Air Cooled
Thx. Ya they were working fine. Then I jiggled some and nothing. I thought this may be it. I’ll start at the fuse...
Analog Air Cooled
Thank you. Turns out I must have done something because the blue fuse was
Popped. I had spares thankfully. She works. So yes that 4 Pin must be for auto heat to which I don’t have.
