Uncertifiable!!!
Uwon's Avatar
Whining 915 Trani
My trani has a momentary low rpm rattle if I lug the motor in any gear which turns into a whine at higher speeds and very high pitch at cruising. Whine not gear dependent. Shifts like butter. Can’t say that the whine is getting worse- may have always been there. Swepco oil to middle plug on driver’s side.
Trani was refurbished a couple of years ago by a knowledgeable strictly Porsche indi shop more as a perceived precaution as it already had 400k+ km (250k+ miles) and more than 10 DE track seasons.
Work done:
(1) replaced synchros and dog teeth for gears 1,2,3 and sliders for 1-2 and 3-4 with all OEM parts
(2) one surprise was the retaining bolt for the shifter detents pulled from the case so Yarko had to drill and timesert the case
(3) replaced the 5 needle bearing cages under each gear that fell apart when gears removed - replaced with OEM new.
I don’t know much about transmissions but maybe it’s time for me to venture directly into the matter.
Any thoughts and suggestions would be welcomed.
TIA
Cheers,
Johan
Living well is life's best revenge- George Herbert (1593-1633)
‘71 911T resto, 2006 C2S, A4 Quattro, the RST long hood hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 11-11-2019, 09:56 AM
kevingross's Avatar
Looks like the bearings were not done. That could be your problem.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 11-11-2019, 10:13 AM
Uncertifiable!!!
Uwon's Avatar
Ya got me!
Which ones?
Johan
Old 11-11-2019, 11:40 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
On your turbo?
My first guess is a worn 5th gear set. But you say it is not gear dependent.
Could be ring and pinion. Were those bearings replaced and was the backlash and preload checked?
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-11-2019, 11:46 AM
I would guess pinion bearing in the diff housing, possible loose pinion bearing outer race in the diff housing, bearing retainer plate worn so the bearing(s) have end play, maybe even worn R&P from above issues. Teardown and see.
206 637 4071
Old 11-11-2019, 12:02 PM
Jonny042's Avatar
Agree with the above - there's a reason why the 915 is commonly fitted with the one piece bearing carrier. Good info here:
Porsche 915 Rebuild - One Piece Bearing Retainer Plate
Keep in mind, for those that don't know, - Johan now has probably close to half a million KM on this 915, with a healthy boosted motor feeding it as much torque as it can swallow..... so it doesn't owe him much!!
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The Rot Rod! AX beater
Old 11-11-2019, 06:04 PM
This happened to me years ago on a VW Vanagon. I tuned up
My radio and that worked for a few more thousand miles! But then. Went to shop for ring and pinion.
Old 11-11-2019, 09:53 PM
kevingross's Avatar
Originally Posted by Uwon View Post
Ya got me!
Which ones?
Johan
I'm not a fan of doing "some" of the bearings. Some previous did "some" of the rebuild, and here you are today. Just do them all: do it once, do it right.
Kevin
Old 11-12-2019, 08:08 AM
Uncertifiable!!!
Uwon's Avatar
Well, thank you all for your valued analysis and suggestions. Looks like the consensus is bearings and ring/pinion.
Seeing my winter project list is not that long this year, I have the time to educate myself and tackle the rebuild. Never done this before so I have some reading to do. I plan to drop the Powertrain on the RST in January and will post my progress on this thread. I’m sure that I’ll be soliciting your collective help from time to time.
Cheers,
Johan
Old 11-12-2019, 05:50 PM
gearhead
The way to avoid the cost of a ring and pinion is to stop driving it and do the bearings now.
1974 911 Restorod
1974 914 Bumble Bee
2004 40 Jahre
2008 Cayman S Mule
Old 11-12-2019, 05:52 PM
Jonny042's Avatar
Cheers,
Johan
I'm going to be doing one too (for Project Heavy Metal)..... so not only will it be fresh in my mind, my tools will be warm - you're welcome to borrow them.
Transmissions are fun, and easy, to work on. Well, relatively, at least. I'm sure you've seen peter zimmermans tutorial, it's a good place to start, and Gordo (or is it Gordo2?) has a few excellent threads as well.
Given that you may have to send out the diff housing for repair, the sooner you can tear into it, the better. Things have a habit of dragging out, and if it takes 4 or 5 weeks (return) for that, it may end up cutting into your spring driving time.
Old 11-13-2019, 06:39 AM
Uncertifiable!!!
Uwon's Avatar
Wow, thank so much for your kind offer. I’ll email you to coordinate.
I need a new challenge so I’m starting my tutorials per your suggestions. You have an excellent point on timing and possible repair to the diff housing. Got to finish lowering the 997S right away.
Cheers,
Johan
Old 11-14-2019, 03:19 AM
Uncertifiable!!!
Uwon's Avatar
Update!!!!
Well, Jonny042’s handy toolS came to the rescue. Thank you Jon.
Partially dismantled the transmission and differential, but could not find anything amiss. Replace all seals and gaskets.
The whining, as best as I could diagnose, was a very noisy release bearing which I have now replaced.
Cheers,
Johan
Old 05-11-2020, 07:24 PM
Whew! Sounds like you got lucky...
Old 05-11-2020, 08:08 PM
Bill Douglas's Avatar
Excellent outcome.
see www.lyallbaybeach.co.nz
Old 05-11-2020, 08:58 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
