valve cover torque
What is the correct torque setting for valve covers 1975 2.7 911S
Old 11-09-2019, 02:40 PM
Crusty Conservative
silverc4s's Avatar
5 lbs? Very low for sure, or they will leak.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 11-09-2019, 02:48 PM
Crusty Conservative
silverc4s's Avatar
If your covers are no longer flat they will leak at any torque. Check them on a pane of glass or other known flat.
Bill
Old 11-09-2019, 02:49 PM
valve cover torque
8Nm. Cross pattern.
they are new turbo type covers they should be flat thanks I'll go with 5-6 lbs
thanks
Old 11-09-2019, 02:56 PM
HarryD's Avatar
Tighten the nuts down until they just touch. In a criss-cross pattern inside to out, turn each nut one 1/4 turn. Fill engine with oil, warm up, look for leaks. tighten another 1/8 turn at any leaking points. done!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-09-2019, 03:22 PM
Troll Hunter
8 NM (NOT FOOT LBS!)
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/17-Turbo_Valve_Covers/17-Turbo_Valve_Covers.htm
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 11-10-2019, 07:35 AM
cycling has-been
bkreigsr's Avatar
Some machine shops will sand these flat on their sand belt table.
My local guy didn't even charge me.
I also bought a 1/4" drive torque wrench specifically for this task. Do not over-torque.
Bill K
Old 11-10-2019, 09:13 AM
T77911S's Avatar
if you use the silicon reusable gaskets do it by feel and how much the gasket squeezes out.
it should NOT squeeze out. the torque is so light on these you will feel like they are not tight enough
these gaskets are great because they seal well and you can reuse them.
if they leak then just snug the nuts a tad more.
just a note for anyone out there, do NOT use gasket sealer on any valve cover gaskets.
I also run a die over the studs on the cam towers to clean the threads up.
make sure both surfaces are clean
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-12-2019, 06:25 AM
Flojo's Avatar
I remember for my SC to be 10 Nm and a retorque if necessary to 11 Nm after seating (first drive)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-12-2019, 07:10 AM
Reiver
Reiver's Avatar
I don't know what the dif would be between the 2.7 and 3.0 but the Porsche trained tech that rebuilt my 930-10 does 15 ft. lbs....and I do too when I adjust valves with no leaks ever....and no issues.
Just cross tighten.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-12-2019, 07:59 AM
SCadaddle's Avatar
Just cross tighten.
Sho do! I did too!
Old 11-12-2019, 08:08 AM
Reiver
Reiver's Avatar
Lol...nice grille my man....how did you Dog swipe your bling?
De Oppresso Liber
Old 11-12-2019, 08:33 PM
