Heater hose
Hello I have a question? do anyone know the heater hose size for a 79 sc with factory a/c I heard it two sizes, and it's very difficult to order, because I can't figure out the right size. it wasn't there when I bought the car. thank you for the help it's cold now.
sylvester Last edited by sylvester; 10-17-2018 at 04:03 PM.. Reason: Mistake |
The large tube is 60.mm and small is 50mm using two reducers
I’ll get part numbers and edit Bruce |
Thank you Bruce that's all I need.
sylvester |
Coudnt find. Part numbers
Bruce |
I'm going through research on the two different hoses. Here is what I've found as the details are not given with the parts descriptions on this site - at least I didn't find them. P/N 91121127400 is the smaller (50mm) diameter hose that is used on cars with A/C and connects at the blower with a reducing collar and another reducing collar at the lower right connection under the A/C Compressor bracket. P/N 91121152200 is 60mm in diameter and is used on cars without A/C. No reducing collars are used.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Still here
Alternative is to order the equivalent SCAT, SCEET etc aircraft hose. These are flexible and more durable than the paper mache OEM hoses.
