High Wattage H4 Bulbs
What make of high wattage bulbs ( 100 w high beam) are you guys using (and are happy with), and where have you purchased them?
These are for an SC with added head light relays. Thx |
Coram Deo
I bought the Hella 55/100W bulbs from our host. Put them in years ago and they continue to work just fine. $5.75 each.
https://www.pelicanparts.com/More_Info/PELH455100.htm?pn=PEL-H4-55-100&SVSVSI=1012&DID=34272
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Rescuer of old cars
I had Hella 80/100W in my '84 with relays. They worked fine, although realistically the increase in light output over 55/60 is minimal. Don't expect miracles.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Coram Deo
I am very happy with the light output. I don't understand how to justify spending $1000 on LED headlights when pretty much the same effect can be had for $11.50 plus shipping.
I think that maybe I'm dreaming.. Last edited by 964TargaC2; 11-28-2019 at 01:00 PM.. |
Formerly known as Syzygy
I think if I was using bulbs of that 130/90 W variety, I'd upgrade the wiring from the relays to the lights (and relay to battery) and use ceramic plugs for the high heat of the bulbs.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
You have to be careful with 100w bulbs in that they will often melt the connectors.
I prefer LED bulbs.......and not those $1000 things but just the LED bulb. Work great for me in my 1973.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Thank you Kevin. Good information that I will consider when the time comes for the install, especially the ceramic plugs, if I can locate them.
Even with the better focus of the H4 system, high-wattage
bulbs are usually not the wise pick. With upgraded wiring and relays in the headlamp circuit It's tempting to grab for big wattage numbers, but it's usually counterproductive. Please see bulb test results posted by Virgil on CPF Interesting headlight bulb test results Note how the only advantage the 100/90w bulb gives is in amount of light on high beam. Seeing distance on low beam is inferior to that from a high-luminance/high-efficacy 60/55w bulb. The current best pick in 60/55w bulbs is made by Tungsram (GE of Europe); it is a +120 item that is a few developmental iterations improved over the +80/+90 bulbs in the linked comparison. Daniel Stern keeps them in stock for $43.18/pair.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
