Air Injection Smog Pump Port Plug - How Difficult
I still have the piping system on the '77 2.7. Looking to see how difficult it is to remove and plug with the part offered on the host site. Guessing similar Degree of Difficulty with removing exhaust headers? Heat it up, use Kroil, etc...?
Any other Tips? thanks! J
J 911 SC - 1980 911 S - 1977 |
Registered Minimalist
It's a bit of work. It can be done without removing the HEs. Kroil, yes, will probably help where the air pipe threads onto the air injectors. I think there is one that is nearly impossible to get to. I used a small crescent wrench to get in there and break it loose.
If I remember correctly, you must remove the muffler as the check valve is bolted up through the bottom of the rear engine tin. There isn't a lot of space in there either. Again, I used two small crescent wrenches to unbolt the check valve.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
1/8" hex head brass pipe plugs fit nicely. Cheap too.
Caveman Hammer Mechanic
Did my 2.7, hardest part was jacking the car up, total non event.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Hi John - would the 1/8" hex head brass pipe plugs work on a 3.0 78 SC motor as well?
Looking to take mine off as well - pump has been out for years now. Thanks Rob!
________________ 78 911 SC Targa 11 Cayenne Base 15 Macan Turbo |
Yup, same setup.
