-   -   Can the sliding seat rails be separated while installed. At a loss for bolt removal.. (http://forums.pelicanparts.com/porsche-911-technical-forum/1045390-can-sliding-seat-rails-separated-while-installed-loss-bolt-removal.html)
Hotshot 11-18-2019 05:21 AM
I need to find out how to get at the two drivers side front bolts. I tried cutting an M6 key, no joy.. only guess is that bottom and top sliding rails came apart to get at it.. am I missing something?
The only thing that seams to be an issue with my fantastic running 86 is that the drivers side seat support rails were cut and re welded about 4-5” aft. No clue if it was the PO or PPO or PPPO... And it’s ever so slightly not square, just a mm or two to add to bolt frustration. Not really and issue, unless you want to take the seat out....
I missed it on my inspection and I don’t really mind it as I’m tall, except I have no idea how the PO got the Steve Wong chip in the DME as it’s placed more rearward. What sorcery did he use to get at it.
I’m thinking the bottom and top rail were spilt and slid off. Then the bolts taken out...
Pax seats stock and clean like rest of car. I’m debating at some point having new support rails put back to stock as I’d fit both ways. But that’s above my wrenching abilities....
Thx in advance.
http://forums.pelicanparts.com/uploa...1574082800.jpg
freeform911 11-18-2019 05:34 AM
Did you try sliding the seat all the way to the back?
Hotshot 11-18-2019 06:06 AM
Yes.... that is all the way back. See my issue..
Like I said the pax one is fine, except a stubborn bolt. Full forward, take out back, slide back, take out front.
This is different due to the mod.
86 911 Targa 11-18-2019 06:30 AM
Seized bolt.
https://www.google.com/search?sourceid=navclient&aq=&oq=seized+bolts&ie=U TF-8&rlz=1T4GUEA_enUS570US570&q=seized+bolts&gs_l=hp. ..0l4j0i22i30.0.0.0.6605...........0.pjD3MP_1qRE#s pf=1574087314693
This link & patience might get you by.
Best,
Gerry
porsche930dude 11-18-2019 06:38 AM
if you take out both on the easy side there shouldnt be anything stopping it on the hard side and itll move all the way. Right?
blucille 11-18-2019 07:28 AM
a ball-headed allen wrench on an 1/4" socket might just do the trick, especially if you were able to break them free with your shortened L wrench
Hotshot 11-18-2019 09:43 AM
I can’t get any turn on the shortened wrench. It’s crazy. The others came off fine so being stuck isn’t the issue. It’s trying to get anything in.
That’s why I think the seat tracks were somehow separated, both lower fixed one and upper slide one. That way allowing you to come in at it from the top unobstructed.
And finally the track put back on
Teutonics 11-18-2019 10:20 AM
Is there anything blocking the seat from sliding back farther? Maybe a bolt (or bolts) in the slider track, or even debris keeping it from fully extending? Or is the seat physically being obstructed by something? Maybe try raising (or lowering?) the seat to the maximum height to see if it clears?
Hotshot 11-18-2019 10:30 AM
I did that. But I’ll look hard again fat it. Problem is the seat power is out ( hense me getting in there ). I haven’t found out if where the stops are that.. stops it. Need more light. You bring up a good point.
Teutonics 11-18-2019 10:47 AM
One possible option (if you have room... kind of hard to tell from the pictures) is to find a hole (or drill a hole) from the top side of the slider to fit an allen wrench down through. If you don't have enough room at the front of the bracket with the seat in place, try finding a hole in the slider somewhere in the middle, slide the seat forward until the hole aligns with the bolt.
Hotshot 11-18-2019 11:19 AM
The holes are there. There in just like a stock setup. There stock bottom plates too.. it’s just how he got them back in and tightened boggles me..
Yes I tried contacting him.. natta.
HarryD 11-18-2019 12:10 PM
Hard to tell from the pictures, but maybe if you bend the hex to be at a 45 instead of a 90 degree angle you may be able to get it to turn.
GH85Carrera 11-18-2019 01:51 PM
On my 1985 getting to the bolts is near impossible if the seats are lowered with the electrical motors. I just raise the seats to the maximum with the switches, and it is easy to get in there. If you don't have electric seats, it will be a challenge.
Hotshot 11-24-2019 09:42 PM
My electric seat fuse popped twice since I've been messing about. I know you can override the motor with one of the tool kits hex. Have to deal with a short now.
How does raising the seat motors clear access to the top of the bolt when it’s the top part of the rail that’s blocking the bolt?
T77911S 11-25-2019 04:18 AM
you have mechanical sliders for moving the seat forward and backward correct.
its been a while since I had mine out, but one side can get "out of alignment" from the other if I remember correctly. that is, if one side is unbolted and you move the seat forward, the sides are not aligned,
try unbolting one side and then moving the seat. could be that the other side is limiting how far the seat can move.
just a thought.
Hotshot 11-25-2019 06:25 AM
I like it. There’s definitely a n alignment issue as the left seat seems to be 1/4” out. I didn’t realize the tracks can be off. That’s good as I was concerned the re welding of the seat support rails were out. Then again, the PO had to have this seat off. Thx
Teutonics 11-25-2019 06:54 AM
Where are you located? Maybe there's a second set of Pelican eyes nearby that could take a look... or have another car to look at to compare differences?
Hotshot 11-25-2019 07:04 AM
Toronto sir!
blucille 11-25-2019 07:42 AM
get yourself something like this
https://shop.snapon.com/product/Ball-Hex-Standard%2C-mm%2C-Chrome-(1%2F4%22)/8-pc-Combination-Drive-Metric-Ball-Hex-Bit-Socket-Set-(3-10-mm)/208EFTABMY
Cajundaddy 11-25-2019 07:42 AM
Something is preventing that slider from going back all the way. Solve that puzzle and you will have access to the bolt. Seen this before with race car seats and there is always a reason, just need to find it.
Hotshot 11-25-2019 08:48 AM
Indeed. You guys on here rock. Just sayin.
Hotshot 11-25-2019 08:50 AM
It’s funny, I have this issue on the drivers side. And on the pax side it’s stock and I have a rounded out rear bold that needs Dremal 101
boyt911sc 11-25-2019 10:32 AM
Thread lock.......
Hotshot,
Some of these seat rail bolts still have some traces of thread lock and makes the removal next to impossible. I had stripped a few of these seat rail bolts attempting to remove them without success until I realized they had some sort of thread lock applied to the bolts. I borrowed an inductive heating tool from a member of this forum and after heating up the bolts, they came out with less resistance.
You need to find a way to get access to these bolts. Something is preventing the seat rails from sliding all the way front or back. This is your first goal to achieve before you will be able to get these stubborn bolts out. Don’t give up.
Tony
aston@ultrasw.c 11-25-2019 10:50 AM
Here is a last resort method that I have used with success.
Get a 1/4 metal chisel, line it up on the head of the bolt at a slight angle. The goal is to cut into the head and apply a turning force at the same time.
Obviously the bolt will be trashed, but if you get the angle right and give it a sharp whack it *might* turn for you.
T77911S 11-26-2019 03:55 AM
I welded an allen wrench to one bolt.
yes I covered everything inside the car to protect it.
tony had the best suggestion, heat. but an inductive heat source hot enough is the issue.
try unbolting one side, then try moving the seat again. you may get room
Hotshot 11-26-2019 06:31 AM
Trying. With the driver seat it’s the 2 fronts I can’t get lose. But agree that something must me in the way or blocking.
T77911S 11-26-2019 10:11 AM
and you have cut the allen wrench down and that did not help
Hotshot 11-26-2019 10:18 AM
Nope. It fit but can’t turn. Those snap on bits lot great. $$$ though.
blucille 11-26-2019 10:25 AM
there are plenty available that are similar but less money
T77911S 11-27-2019 03:43 AM
cut the end down so it fits.
Hotshot 11-27-2019 04:33 AM
Did that. No joy. Must be a block or a jam.
porsche930dude 11-27-2019 07:56 AM
have you taken out all the other bolts?
wrxnofx 11-27-2019 08:38 AM
The way it’s SUPPOSED to work is, slide the seat all the way back. That gives you access to the front bolts with a 1/4” hex socket and 1/4” wrench. Then, with the fronts out, you can slide the seat really far forward and access all 4 bolts at the back.
If your seat won’t slide back far enough to access the front bolts there is something blocking the seat rail slider.
The seat rails are indeed staggered slightly with respect to each other. One of mine is slightly forward of the other.
Hotshot 11-27-2019 09:37 PM
Update
Well, after another pair of eyes is on it, I think I found the way they come out...
Via a hole in the rail track. Remember, some PO between 86 and Nov, had the seat support rails cut and rewelded 5” aft, so forget the bolts being accessible the normal way. So while sliding the seat forward there’s this hole.
I was able to loosen one bolt, but need to make another tool. My ball ends are too big and I can’t get a wrench and socket in.. as you can see the M6 Hex can’t go anymore counter clockwise without obstruction..
http://forums.pelicanparts.com/uploa...1574919249.jpg
Evans, Marv 11-27-2019 10:05 PM
I might try cutting my allen wrench down some.
samurai_k 11-27-2019 10:55 PM
Do you have powered seats that adjust the height of the seat? Have you tried to raise the seat on both ends to give you some extra room to get a tool into that tight spot?
Hotshot 11-28-2019 06:04 AM
Yes. That’s all that way up in the pic.
Hotshot 11-30-2019 05:33 PM
Success!! You Need this tool.
After talking to a local Indy specialist who has forgotten more than I know, he said he had just the thing. He lent me these and I am grateful. I’m also ordering them.
My previous pic on using the side rail is correct but you need a very high quality M6 hex and very shallow. I was also able to get a factory pax seat bolt off I thought I was going to Dremel. Amazing what pro tools get you in a jam. So here it is.
A very shallow bit, and a wobble end extension. Just awesome tools.
http://forums.pelicanparts.com/uploa...1575163484.jpg
freeform911 11-30-2019 08:37 PM
Well...glad you finally got it....
Love when a 10 minute project turns into a 7 day one...
Hotshot 12-01-2019 01:08 PM
Yup....
