Designer King
What Do I Need For A Suspension Refresh?
Ol Yeller has 197,000 miles on it so I think it's well past time I did some suspension freshening. I've already redone the front rotors and pads, all 4 wheel bearings, and the turbo tie rods.
I want to replace, or have revalved, the Bilstein HD shocks, and replace the sway bar bushings and drop links or bushings, along with the spring plates and/or bushings. I'll probably replace shock mount bushings too. Afterwards I'll have an alignment done. I don't track the car anymore, and at my advanced age (71) I'm looking for a well handling but comfortable ride for myself and my long suffering wife. Aside from what I've listed above, what else should I get from our host, and what potential pitfalls should I look out for, or special tools would I need to do this work? And finally, can I do all this work in my garage with a jack and stands but no lift? Thanks.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L '80 SC engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Goodrich G Force Sport Comp 2; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-19-2019 at 09:08 AM.. |
I would rather be driving
Here is my typical list for a refresh. Some parts may be deleted depending on the previous replacement. There are options for each item.
front shocks (dampers) Front a-arm bushings tie-rods (or tie-rod ends) ball joints Steering rack rebuild/regrease front sway bar bushings (front a-arm and rear support) Front strut bearing support (top of strut) rear sway bar bushings (drop link and body collar) spring plate bushings rear shocks (dampers) rear trailing arm bushings I am a huge fan of any of the bearing type bushings (not rubber) I don't think they transmit much NVH into the chassis but have fantastic reduction in rotational friction. This means a planted, compliant ride especially on bad roads. Make sure to add a corner balance to your alignment process. This makes a difference especially after it has all come apart and been assembled.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine classicautowerks.com - EFI conversion parts and suspension setups. |
Banned
well handling but comfortable ===> digressive valving on the shocks
for best comfort, reverse all the hotrod suspension mods. you did years ago |
You can definitely do this on jack stands. I did, but I'm also not 71
1982 911 Targa, 3.0L ROW with Webers |
If you have a Bilstein struts, you should probably change the upper seal and the sliding bearing inside the struts too.
Designer King
Thanks everyone.
Mar2mar, Our host's chat function isn't working right now. Are those 2 parts readily available?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L '80 SC engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Goodrich G Force Sport Comp 2; PCA/UCR, MID9 Never leave well enough alone |
I searched around quite a bit for these parts, hoping to rebuild it myself , but I didn’t find anybody that sells them. Finally I called Bilstein, they have the parts , but they will not sell it individually. You have to send the struts to them and they will install it. That’s what I did. Before tax and shipping they charge a total of $230 for both struts. The turn around time was about 2 weeks. I’m very happy with their service and the peace of mind knowing it was professional done by Bilstein is well worth it.
Designer King
I think I'll go that route, Mar. Thanks!
Craig Garr (G2 RAcing) (Cgarr on Pelican) will rebush your Bilstein struts. His turnaround time is faster than Bilstein and at a very reasonable price. It is worth contacting him.
Designer King
I'll check him out.
Thanks Jamie.
Eva
Check book, thick one
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Thread Tools | |
Rate This Thread | |
