79 SC oil drip, what is it?
Have been chasing down some minor leaks on my car and this one remains. It only drips when running but falls on exhaust so is particularly annoying. Drip coming from red circled area adjacent to right lower valve cover. Thanks guys.
Old 11-20-2019, 10:34 AM
Could be a rocker shaft leaking. Put some oil dye in the tank, drive it for a day or two, then inspect with a black light. It'll show up.
Old 11-20-2019, 11:01 AM
proporsche's Avatar
hi Derek
have a look here..it could be your camshaft oil line fitting to the camshaft housing seal.The oil line might look tight but to check loosen the 17mm bolt and check the fitting.
If is is all ok ,it could be your camshaft cover o ring and gasket.
black arrow
1985 911 with original 502 191 miles...808 198 km
Old 11-20-2019, 11:05 AM
