Raid interchangeable with Momo
I've currently got a Momo Prototipo steering wheel and was wondering if that's an easy swap to put in a Raid3 steering wheel. Does Raid use the same adapter as the Momo or would I need to purchase something to make this swap possible?
1987 Porsche 930 - Grand Prix white 1998 Acura NSX - Kaiser silver 1976 Jeep CJ5 - Sunshine yellow |
Correction, I've got a Momo Mod 07 wheel if it makes a difference.
You’ll need an adaptor. I’ll post what you need in a bit.
Ass-engine Nazi slot car -- PJ O'Rourke |
Awesome, thanks jac1976
Ebay is another source. It's a relatively low-tech product. Source it in aluminum instead of steel.
Sherwood |
Thanks Sherwood. I just confirmed that the adapter in the previous link is aluminum.
I would rather be driving
for reference...
Nardi/Personal/Raid wheels use a 6 bolt 74mm pattern. Momo uses a 6 bolt 70mm pattern. The adapters have offset holes for each bolt pattern. Just be careful that when clocking the wheel on the adapter that your Turn signal cancel tab ends up in the correct place. The best way would be to purchase the correct steering wheel hub for the wheel.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I'm good with tools.
[QUOTE=jpnovak;10666021] Just be careful that when clocking the wheel on the adapter that your Turn signal cancel tab ends up in the correct place. [QUOTE]
^ Big thumbs up. I ended up getting the correct adapter..... No more issues.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
scumbag
And be cautious with those eBay adapter rings. They aren't always concentric and you get a strange orbit instead of rotation of the wheel. At least the guy in the bottom of my tool chest did.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Thanks guys. Something like this?
https://jhpusa.com/products/nardi-personal-steering-wheel-hub-porsche or this... https://www.amazon.com/Nardi-Steering-Adapter-Porsche-Models/dp/B0728B4QQF?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B0728B4QQF
The adapter in question is to accommodate the different bolt patterns from one's current configuration. Thus, it's to change Momo to/from Personal/Nardi wheel bolt patterns. It's not rocket science and the proper multi-drilled aluminum plate doesn't have to cost more than 20 bucks.
Sherwood |
