Aluminum scissor jack
When were these first available and for what cars? I may be needing a very light aluminum jack. And if anyone has ideas about a non-Porsche jack that would work, I am open to ideas.
Thanks guys!
Old 11-19-2019, 05:16 PM
FrenchToast's Avatar
For what purpose? As a real jack or only to change a tire?
The scissor jacks shouldn't be used for anything other than changing a tire. In other words, they're pretty crappy.
I would guess the AL scissor jacks appeared sometime around 1980 but have no idea. PET might tell you.
Old 11-19-2019, 05:46 PM
alu scissor
I am told they came with 964s. Purely for an emergency tire change. Hope to never use.
If you have an extra please PM me. Promise I won't hold you liable.
Old 11-19-2019, 05:51 PM
SWS911's Avatar
Lars, Search "jacks" in the 944 parts forum and check out plyhammer's thread. He has a ton of 'em!
Old 11-20-2019, 05:18 AM
The aluminum jack also cam stock in 928s from 78 on. I have a spare aluminum jack from my wrecked 85 928. If you're interested I'll part with it for a very reasonable price.
Old 11-20-2019, 05:55 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
I was just looking at these flat compact billet ratchet jacks:
https://www.calcarcover.com/product/low-profile-billet-aluminum-jack/705?bvstate=pg:2/ct:q
Not sure it is any better than what's available from the Porsche factory.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 11-20-2019, 06:05 AM
Cory M's Avatar
They came on 944's. The factory 911 jack works better because it mates with the lift hole in the rocker. The aluminum scissor would have to be e placed under the chassis somewhere.
Old 11-20-2019, 06:40 AM
famoroso's Avatar
I have two of those for use on my Lotus. Normally, I use them as stage one to get the vehicle high enough for a standard floorjack. As you can see from the attached pics though, they can be used for more than that. They don't provide a great deal of ultimate lift, but they are for sure low profile.
They are all metal and I would imagine they are better than other scissors jacks, especially any scissors jacks that incorporate plastic parts.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 11-20-2019, 10:24 AM
AutoBahned
RWebb's Avatar
The factory 911 jack is called "The Widowmaker" for good reason. Get an Al 944 jack and adapt it to your car.
Old 11-20-2019, 11:28 AM
I use a screw jack off a 54 Bentley! It can lift 5500 hundred pounds safely, gets great height, and, unlike the factory jack has a great wide base.
I quit using my 73 factory jack when it sank into the asphalt between Laredo and San Antonio in the middle of August, circa 1974.
Probably still stuck there.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-20-2019, 01:52 PM
An aluminum 944 scissors jack is light, cheap (used) and a lot safer than the "widow-maker" factory jack. Works fine under the control arm and on wooden blocks if using a rocker receptacle jack adapter. As with all jacks, use a sturdy jack stand as the main support if you value any part of your body.
S
Old 11-20-2019, 03:04 PM
I use the 944 aluminum jack with an adapter plate in the factory jack point on my SC. I have used it quite a bit due to a slow leak in a rear tire that’s too good to toss. It’s been up and down at least 30 times and has held up well. I feel it creates less torque (it will slide before it twists) on a less than level surface to lessen the potential to twist the welded chassis jack point. I cut a rigid foam insert and fit it around the jack and store it in the trunk in front of my spare.
Old 11-20-2019, 08:15 PM
