Clocking of clutch release fork
I was hoping this would be obvious when it came to put the parts together, but it isnt.
#1 Release fork is splined to the shaft #2 #13 Clutch released lever floats on the shaft (non-issue) #18 Change Lever is also splined to the shaft. http://forums.pelicanparts.com/uploa...1574362866.JPG I assumed that I would clock #1 and #18 in line with each other, but in that configuration #1 Release Fork would have very little travel to release the pressure plate. http://forums.pelicanparts.com/uploa...1574362981.jpg This alignment of #18 makes the most sense, red line is approx position of #1. http://forums.pelicanparts.com/uploa...1574363208.jpg There must be a correct way to set this up, but I have found nothing in the Pelican search history or Bentley manual. Appreciate any pointers! |
your solution is very simple;-) remove the clutch arm and the little finger..After you install engine and trans....then install the arm and little finger + spring .Also do not forget to use the seals..number 4 ,one inside and two outside....you see simple...
Ivan |
Appreciate the reply, Ivan.
So when the #1 release fork is held in position by the throwout bearing will there only be one logical position (clocking) of the #18 Change Lever? Or do you just select the rearward most position to get the maximum travel? |
Once you have the all in the car.Hook the clutch cable to the arm and pull towards the back of the car with a big screwdriver to power over the Omega`s spring tension.The you instal another seal and little finger with the spring.leave a play in it..Adjust your cable to the specs-there are more then one link in here - i`m sure you can find out.After your clutch is adjusted adjust the play on little finger...that is all...Oh ya lube everything.............
Ivan |
Makes sense...
Regarding the seals, I have two o-rings and one shaped seal. I'm guessing the shaped seal goes on last with the small arm #18 (yellow), and the o-rings go where marked green. Does this look correct? http://forums.pelicanparts.com/uploa...1574369298.jpg |
those 3 seals should be the same..
https://cdn5.pelicanparts.com/catalo...113900-M30.jpg |
Looks like the Elring 915 trans gasket set only provides one of those shaped gaskets. I'll order a couple more separately.
Thanks again for your help Ivan. Matt |
u r very welcome.
Ivan |
| All times are GMT -8. The time now is 04:50 PM. |
